Insteon I/O LInc will not link
My i/o linc I've had a couple of years seemed to quit working with ISY a day or two ago.  At linc itself, pushing button switches as it should.  I can't add it to ISY.  I've tried resetting, moving it to where PLM and it are on same outlet, installed the latest version of admin control, have latest version of java with no old files.  each time i get the old cannot determine insteon engine.  I've tried adding it manually and by linking automatically, with same results.  Thinking i/o linc may have stopped working in this capacity.  Here's event log for what it's worth:
Thu 07/14/2016 11:18:31 AM : [23 d3 47    ] Added to list of devices to link to ISY
Thu 07/14/2016 11:18:31 AM : [iNST-TX-I1  ] 02 62 23 D3 47 0F 0D 00
Thu 07/14/2016 11:18:31 AM : [iNST-ACK    ] 02 62 23.D3.47 0F 0D 00 06                 (00)
Thu 07/14/2016 11:18:40 AM : [iNST-TX-I1  ] 02 62 23 D3 47 0F 0D 00
Thu 07/14/2016 11:18:40 AM : [iNST-ACK    ] 02 62 23.D3.47 0F 0D 00 06                 (00)
Thu 07/14/2016 11:18:49 AM : [iNST-TX-I1  ] 02 62 23 D3 47 0F 0D 00
Thu 07/14/2016 11:18:49 AM : [iNST-ACK    ] 02 62 23.D3.47 0F 0D 00 06                 (00)
Thu 07/14/2016 11:18:53 AM : [23 D3 47 0  ] Failed to add device, reason 3
Thu 07/14/2016 11:18:53 AM : [All         ] Writing 9 bytes to devices
Thu 07/14/2016 11:18:53 AM : [2E 93 49 1  ] Link    5 : 0FD0 [620223D347010002] Writing [62..............]
Thu 07/14/2016 11:18:53 AM : [iNST-TX-I2CS] 02 62 2E 93 49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D
Thu 07/14/2016 11:18:53 AM : [iNST-ACK    ] 02 62 2E.93.49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D 06        (00)
Thu 07/14/2016 11:19:02 AM : [iNST-TX-I2CS] 02 62 2E 93 49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D
Thu 07/14/2016 11:19:02 AM : [iNST-ACK    ] 02 62 2E.93.49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D 06        (00)
Thu 07/14/2016 11:19:11 AM : [iNST-TX-I2CS] 02 62 2E 93 49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D
Thu 07/14/2016 11:19:11 AM : [iNST-ACK    ] 02 62 2E.93.49 1F 2F 00 00 02 0F D7 08 62 02 23 D3 47 01 00 02 3D 06        (00)
Thu 07/14/2016 11:19:15 AM : [2E 93 49 1  ] Link    5 : 0FD0 [620223D347010002] *Failed Writing [62..............]
I just replaced the PLM a couple of weeks ago and it is 2413S ver 2.2
The i/o linc is 2450 V2.3
I've tried plugging in the i/o on both sides of my house phases with same results.
Not sure if there is anything else to try.
And in case you wanted to ask, it wasn't/isn't listed in the device listing under network. Any help appreciated.  thx
Sounds like the problem I had with my 5.x SwitchLincs and Keypadlincs. Same message, and I have about a dozen of them legs-up...
I have a couple of IOLincs I haven't tried, as I don't have a use for them after moving. So dunno about them.
See if they will link to another device manually - that is, with keypresses. You'll have to look-up the specific incantations for both devices in the product manuals.
In my case, the devices lost all ability to link to either the PLM or other devices. Insteon support wasn't very helpful. I now have a dozen very expensive dimmers. (At least the dimming function works.)
Unfortunately, there is no use for an IoLinc that won't link! :(
Edited by jtara92101
The I/O Linc is power line only. Try adding it from the same circuit as the PLM.
