RichTJ99 Posted January 8, 2009 Share Posted January 8, 2009 Hi, Right now most of my ramp rates are .1 second (instant on). I would like to set it so that all lights in the house ramp up over 6 seconds after 11pm until 6am. Is that possible or a huge problem? I know to change ramp rates you need to do the air gap trick so I dont know if this would work. Thanks, Rich Link to comment
Michel Kohanim Posted January 8, 2009 Share Posted January 8, 2009 Hi Rich, If you put your devices in scenes, then you can program them without having to airgap. But, the main issue is that programming on level/ramp rates may take a long time (depending on the number of devices in the scene) and it's usually not worth the trouble and extra traffic. With kind regards, Michel Hi, Right now most of my ramp rates are .1 second (instant on). I would like to set it so that all lights in the house ramp up over 6 seconds after 11pm until 6am. Is that possible or a huge problem? I know to change ramp rates you need to do the air gap trick so I dont know if this would work. Thanks, Rich Link to comment
RichTJ99 Posted January 8, 2009 Author Share Posted January 8, 2009 So, you can do it but it might not be worthwhile. Does this mean a program runs at 11pm each night, every light is reprogrammed to the 6 second ramp rate. Then at 6am a new program is launched to reprogram everthing to .1 seconds? Link to comment
Michel Kohanim Posted January 9, 2009 Share Posted January 9, 2009 Hi RichTJ99, Yes and yes. If you really want to do it, make sure you use scenes. With kind regards, Michel So, you can do it but it might not be worthwhile. Does this mean a program runs at 11pm each night, every light is reprogrammed to the 6 second ramp rate. Then at 6am a new program is launched to reprogram everthing to .1 seconds? Link to comment
G W Posted January 9, 2009 Share Posted January 9, 2009 Interesting. Ugly, but interesting. Link to comment
aartech Posted January 24, 2009 Share Posted January 24, 2009 Hi Rich, If you put your devices in scenes, then you can program them without having to airgap. But, the main issue is that programming on level/ramp rates may take a long time (depending on the number of devices in the scene) and it's usually not worth the trouble and extra traffic. With kind regards, Michel Can I change the local on level and/or ramp rate for a single 2476D by a program? I've tried having the single switch in its own scene but can't seem to make it work. Or does it only work when the scene contains a controller and responder? It would be great to be able to change a single switch's local settings based on a program. Maybe I'm just doing something wrong? Link to comment
Sub-Routine Posted January 24, 2009 Share Posted January 24, 2009 Can I change the local on level and/or ramp rate for a single 2476D by a program? I've tried having the single switch in its own scene but can't seem to make it work. Or does it only work when the scene contains a controller and responder? It would be great to be able to change a single switch's local settings based on a program. Maybe I'm just doing something wrong? No, only the levels and rates in scenes the ISY controls can be changed in programs. When you change the local level a switch requires a reset before it takes effect. Rand Link to comment
aartech Posted January 24, 2009 Share Posted January 24, 2009 Can I change the local on level and/or ramp rate for a single 2476D by a program? I've tried having the single switch in its own scene but can't seem to make it work. Or does it only work when the scene contains a controller and responder? It would be great to be able to change a single switch's local settings based on a program. Maybe I'm just doing something wrong? No, only the levels and rates in scenes the ISY controls can be changed in programs. When you change the local level a switch requires a reset before it takes effect. Rand Thanks for the explanation. Is that a limitation of the switch when programmed remotely? I don't need to reset it when I change those levels at the switch. Link to comment
Sub-Routine Posted January 24, 2009 Share Posted January 24, 2009 Thanks for the explanation. Is that a limitation of the switch when programmed remotely? I don't need to reset it when I change those levels at the switch. Yes it is a limitation of the switch. A keypad can reread the values without a reset. If you use the ISY to fine tune the local levels and rates on your switches a quicker way to reset many switches is to cycle the circuit breaker(s) instead of pulling each set button. Rand Link to comment
aartech Posted January 24, 2009 Share Posted January 24, 2009 Thanks for the explanation. Is that a limitation of the switch when programmed remotely? I don't need to reset it when I change those levels at the switch. Yes it is a limitation of the switch. A keypad can reread the values without a reset. If you use the ISY to fine tune the local levels and rates on your switches a quicker way to reset many switches is to cycle the circuit breaker(s) instead of pulling each set button. Rand For me it was an issue of wanting my bathroom light to come on to a lower level at night and full bright during the day, for example... what I do now is set it to a lower level and use the isy to set it to turn it full bright when it turns on during the day. Link to comment
