Secondary not connecting
themlruts
For some reason my secondary connection does not connected. I am using a non standard port and over SSL. The cert is self signed. I can browse https to the URL and port just fine.
Thoughts?
Mike
Thoughts?
Mike
Can you confirm that you have ssl selected and the proper port entered in the connection settings?  Taping the use SSL checkbox will override possible options entered int he port settings unless they are explicitly entered.
Thoughts?
Mike
I had the same issue when I started using Agave. After a long process of elimination, I discovered I needed to drop the key strength of my self signed certificate. I wasn't able to prove it, but I felt the app was timing out before the connection was made.
Dennis
Dennis
Thanks for the info. It's hit or miss and sometimes it takes forever to connect. I don't really want to drop my key stregnth.
James can this be looked into?
      37.3k
      373.8k
