Program question - Press on turns off, press off turns off?
RichTJ99
Hi,
So I want to replace a scene with a program.  What I want to have happen is:
Press button D (on), keypad light goes to 4%
Press button D (off), keypad light goes to 0%
So far I only have half of it:
        Control 'Main House / Bedrooms / Main: Upstair Steve Keypad D' is switched On
        Set 'Main House / Bedrooms / Main: Upstair Steve Keypad' 4%
Rich
Hi,
Rich
add an off statement to the Else clause and change control to status in the IF statement
ELSE
    set keypad to 0
Edited by Techman
Keypad lights only work from scenes.
This. You cannot set keypad lights directly from a program....
True for secondary buttons, not so sure for primary. Also, Secondary buttons, I thought, could be used as program conditions, however. No?
If keypad light is the primary button (and i expect that it is here) then
Sorry, got pulled away on something else.
It appears to me that this program is using a secondary button as a trigger, but commanding the primary button. I understood that one could not issue direct commands to secondary buttons, but thought you could use them as program conditions.
Being uncertain, I tried a quick experiment and found that I was remembering wrong.  Secondary buttons apparently do not even report status, nor can they be used to trigger programs.  Wow.  How long have I been doing this?
LOL
The secondary button triggers programs just fine. I use mine for combination locks wit several different combinations to do different things like reset water leak responses, turning the well pump or washing machine back on or turning on/off the notification system.
But yes the primary LED brightness can be controlled day/night with program control.
     And Control 'Main House / Bedrooms / Main: Upstair Steve Keypad D' is not switched Off
        Set 'Main House / Bedrooms / Main: Upstair Steve Keypad' Off
LOL
I, too, trigger programs based upon status of secondary keypad buttons.  Not being satisfied with my experiment results and looking further, I find that some of my keypad buttons report status, and others (at least the one on which I was doing experiments and likely the oldest keypad I own) does not.  Possibly a comm issue with that particular keypad?  Or do old ones behave different than newer ones?  Oh well.  It is getting late and I am losing interest.
Back on topic, I think stusviews answered the un-voiced question.
Edited by oberkc
AFAIK, the only way to manipulate (turn on or off) the state of a secondary button is to create a scene that has only the button as a responder.
      379.9k
