New ISY User need some help with first program
Guys not sure what I am doing wrong but why would this program make my lights flash instead of running?
Exterior Lights - [iD 0003][Parent 0001][Not Enabled]
        From    Sunset  + 30 minutes
        To      11:30:00PM (same day)
    And Status  'Garage Exterior' is Off
        Set Scene 'Exterior Lights' On
        Set Scene 'Exterior Lights' Off
Edited by Ajax
Try it with the "Else" function blank (no action) and see what happens.
        - No Actions - (to add one, press "Action")
Edited by haroldunger
Yes not sure why but for some reason I could not select a scene for status so I just used one of the devices (Garage Exterior) that is in a 3-way scene (Exterior Lights). If I leave the else statement blank and the lights were turned on my before the program triggered will it still shut off the lights at 11:30 or do I write another program?
I'm not sure.  Set the off time to 9pm and see what happens.  If it doesn't shut the scene down, then write a simple "off" program for 11:31pm and reset the original program to 11:30pm or eliminate the off time entirely.
I would create a scene of just your garage exterior lights. Use that in your "then" statement
It is because scenes have no status in insteon.  Only devices have a status.
Your program is, in effect, creating an endless loop.  The program triggers, it changes the state of the device (as part of the scene), which triggers the program, which changes the state of the device, which triggers the program, which...well...you get the point.
Remove the STATUS condition from the program.  It really serves no purpose, anyhow.
I run a program which checks to see if any of the individual lights included in the scene are on.  The lights are enumerated individually.  If none are on, then the program runs the "then" statement, the scene executes, and all of the lights in the scene are turned on to a predetermined level.  If any one is on, then the program "then" statement doesn't turn on the scene.  It works fine.
This program is a little different than the original-posted program.  Yours has a "if time is..."  Ajax' program has a "if time is from/to".  Your program works fine because there is only a specific moment in time that it can be true.  Ajax program can be true over a period of several hours.  Obviously, Ajax' program also has a non-empty ELSE path.
There are several ways to approach Ajax program.  One could use two programs.  One could use a single program as he is trying.  If the condition "status exterior light is off" turns out to be important, then it might be necessary to break his into two programs.  But, the original intention seemed to be check whether the scene was on, instead using a device within the scene as an indicator.  In my estimation, if a scene is ON, there is no harm in turning it on again.
Edited by oberkc
Here's the last in the series of programs.  The interim program adjusts the lights to the "If" requirements.  So, if I'm watching TV and I have changed the lighting intensity, etc., then this program won't execute.  If not, it executes.  Also, this one has an off time.  It works great, too.
So I did use a device (Garage Exterior) to check if the scene "Exterior Lights" are one-Is that the correct way to check? I will remove the "Status" Since yes in theory what's it going to do just turn in on. But how would I have done that if I did want to check a status first? Since mine looks very similar to the one below but does not work
 Thanks guys
Probably use an approach similar to haroldunger, but you would have to use two programs.  The big difference is that the time condition is a single, discrete, time rather than a range.
time is sunset + 30
and status garage exterior is OFF
then
turn lights on
else
nothing
if
time is 1130pm
then
turn lights off
else
nothing
One of the big things to be aware of is when a program action can cause the program to retrigger (as your original program did) and get in a never-ending loop.  A simple and obvious example would be:
if
status LIGHT is OFF
then
turn LIGHT ON
else
turn LIGHT OFF
While easy to see in this case, it is often hard to see when this is happening in more complicated programs.  I believe it was happening in your case (but only between the time range specified).
Thanks Oberkc, Quick question with doing 2 programs just for turning lights on and off, how many programs total do most guys run? I mean I know it is going to vary, but it seems I am going to spend days just creating the most basic functions
I have no idea about "most" or average. Personally, I have well fewer than 100 programs, but I have no doubt those crazy guys can have orders of magnitudes greater than that. Useing the program folders and comments, it is pretty easy to manage, in my estimation.
Which is another reason I prefered my original suggestion (remove the status condition) and do it in a single program. I suspect you will also find means opportunity to combine programs. For example I might have several programs to turn lights on any given day, but only one to turn all off.
For the most part, I have not found this sort of thing to be a constraint.
Many of my scenes have on and off commands in just one program.  However, I can see dividing the on and off functions into two programs.  I do have a program that turns off everything at 2:30am.
