NodeLink v0.6.0
V0.6.2 cured the confusion of the Venstar continuing saga! LOL
Thank you so much io_guy. You da man!
I take it this will have to be sorted AGAIN if Venstar ever does come through on their end.
I will PM Paul to make sure he isn't using some scrambled parameters now. LOL
So that people can see what io_guy is doing, I am posting this screenshot from the Venstar T7900 thermostat device page from my ISY Admin Console that NodeLink 6.2 has made possible.
I was able to test the humidity active value in the ISY, that works as well. When the colortouch decides to "Run fan with humidity demand" and humidify off-cycle, the "Humidity Active" value in the ISY changes to True. This allows monitoring of humidification to predict pad replacement
Thank you again!
Paul
