IVB Posted September 9, 2016 Posted September 9, 2016 I'm trying to create a program where the F6 button on a keypad toggles a zWave light. I did two programs with: IF BackKeypad.F6 is pressed AND Backyard=On Then Backyard=Off and a 2nd program with IF BackKeypad.F6 is pressed AND Backyard=Off Then Backyard=On As soon as I press F6, the lights start flashing, as if they're being turned on/off. It goes on for a few minutes. The only thing I can think of is that the pressed event lasts a while, so the two programs are triggering each other. Is that my issue? Should I use variables? I tried but the below didn't work at all, as if the variable satisfying the if wasn't being picked up. IF BackKeypad.F6 is pressed AND Backyard=On Then BackVar=0 and a 2nd program with IF BackKeypad.F6 is pressed AND Backyard=Off Then BackVar=1 If BackVar=0 Then Backyard=Off Then BackVar=2 If BackVar=1 Then Backyard=On Then BackVar=2
larryllix Posted September 9, 2016 Posted September 9, 2016 You like to live dangerously! If this is in ISY more information is required about your parameters. IF BackKeypad.F6 is pressed AND Backyard=On <---needs to not cause triggers, whatever this is Then set Backyard Off Else set Backyard off If backyard input is a device it will always cause triggers and may oscillate. A variable and another program will be necessary. Variable Flipper Program IF BackKeypad.F6 is pressed Then $sVariable += 1 <---must be state variable $sVariable %= 2 Else ---- Driver Program (enabled) If $sVariable = 1 Then turn Backyard On Else turn Backyard Off EDIT: Not a good way to do this. See following post.
IVB Posted September 9, 2016 Author Posted September 9, 2016 eh, hmmm, i don't have permission to quote your latest reply, but thats clever, that should do it. Backyard is a zWave appliance module, into which lights are plugged. Thanks! BTW in response to a statement I made earlier, I can't seem to leave my server that runs well enough alone, and i'm the cause of M$ instability. I'm now segregating rules into: Level 1: Elk. Rules that are fully contained within the Elk, such as low voltage lights connected to relays, go here. Level 2: ISY. Rules that are fully contained within the Elk&ISY, such as the above Level 3: CQC. wish me luck...
larryllix Posted September 9, 2016 Posted September 9, 2016 On 9/9/2016 at 5:17 AM, IVB said: I'm trying to create a program where the F6 button on a keypad toggles a zWave light. <snippage> I don't like the above program as it could cause flashing. Light Toggle Program IF BackKeypad.F6 is pressed AND $Variable is not 1 <--- must be a non-triggering element Then $Variable = 1 <---must be Integer variable set backYard On Else $Variable = 0 set Backyard Off
larryllix Posted September 9, 2016 Posted September 9, 2016 On 9/9/2016 at 3:42 PM, IVB said: eh, hmmm, i don't have permission to quote your latest reply, but thats clever, that should do it. Backyard is a zWave appliance module, into which lights are plugged. Thanks! BTW in response to a statement I made earlier, I can't seem to leave my server that runs well enough alone, and i'm the cause of M$ instability. I'm now segregating rules into: Level 1: Elk. Rules that are fully contained within the Elk, such as low voltage lights connected to relays, go here. Level 2: ISY. Rules that are fully contained within the Elk&ISY, such as the above Level 3: CQC. wish me luck... I ain't got no stinkin' Elk so I know not what I have done See my second post.
IVB Posted September 9, 2016 Author Posted September 9, 2016 hey, for the lurkers who have Elks, if I press the F6 button, how long does that event stay in effect? I'm wondering why this'll oscillate for minutes. Shouldn't that trigger only last (seconds, subseconds)? IF BackKeypad.F6 is pressed AND BackyardLight=On Then set BackyardLight Off Else set BackyardLight On
larryllix Posted September 9, 2016 Posted September 9, 2016 On 9/9/2016 at 4:34 PM, IVB said: hey, for the lurkers who have Elks, if I press the F6 button, how long does that event stay in effect? I'm wondering why this'll oscillate for minutes. Shouldn't that trigger only last (seconds, subseconds)? IF BackKeypad.F6 is pressed AND BackyardLight=On <---this cannot be a triggering element Then set BackyardLight Off Else set BackyardLight On Your program oscillates.You are changing the trigger element that runs your program. If it is ON turn it Off Ohh..it changed to Off, turn it ON ohh...it changed to ON, turn it Off
PurdueGuy Posted September 9, 2016 Posted September 9, 2016 Make 2 programs. Program1: IF BackKeypad.F6 is pressed Then Run Program2 If Else <none> Program2 (disabled)IF BackyardLight=On Then BackyardLight=Off Else BackyardLight=On
IVB Posted September 11, 2016 Author Posted September 11, 2016 Oh, I didn't know that a "disabled" program would run via a THEN command. Thats pretty cool. I got it all working with Larry's way, thx all. Climbing the learning curve slowly...
larryllix Posted September 11, 2016 Posted September 11, 2016 Yeah, Disable is only for the triggers feature. Now the program is just a subroutine.
