ISY Portal and viewing cams
Does the ISY portal allow you to view internal cams (they are in Mobilinc) from outside the network. I can see all my switches using the Mobilinc app with the ISY portal. They are Axis web cams.
Thanks Michel
Any security issues with port forwarding I need to be aware of before I do it.
Thanks Michel
It's likely that your cameras would have to support SSL, otherwise you may get a mixed content warning (and some browsers won't render).
