Echo without portal + Raspberry
Hi. Not sure if I'm blind today or just have a brain **** but for life of me I can't find any instructions on setting up Echo with ISY without portal using RaspberryPi.
Could someone please point me in right direction.
It is sort of spread out in this thread.
But just go to BWS Systems and use their ha-bridge software.  It has instructions for use on a Pi.  It is not geared towards the ISY, so you will need to customize the commands a bit, based on the above thread.
I also use Barry Gordon's AWS config tool to make it all MUCH easier to configure.  But you will need the latest 6.0.3 version which I do not think he has  up on this site.
Barry Gordon is top notch.
And then some.  Barry is not only a great code writer, he is a great person.  Very giving of his time.
I got it working now. Special thanks go to Jackal and Barry Gordon.
Great to hear!!!  Now, you should start experimenting with the ability of the Echo to provide responses to your questions!  See the thread of 'Echo talks back'
