Honeywell / Ademco Vista security panels
skunkiechris
I know this was mentioned in a DSC thread from last year, but is there any possibility of getting support for the Vista ICM from Honeywell? I know it broadcasts alarm status messages via UDP on the local network, doesn't seem like it would be too tough to grab them and make actionable items...
*crossing fingers*
Hello skunkiechris,
I had no clue. Is everything based on UDP? i.e. can you arm/disarm using UDP? Any type of security/encryption involved?
*crossing fingers*
Here's a link to someone who has posted a lot of information about what/how it broadcasts, how gain root access via telnet, bulit in debugging tools, etc: http://bliny.net/blog/post/HoneywellAdemco-Vista-ICM-network.aspx
That much would at least allow the ISY to react to alarm events (which would be great!) I know elsewhere there has been discussion, and success, about utilizing the ICM as a go between to arm/disarm the system, although I'm not sure right off on the specifics (I'll have to search around.)
Also, there are some posts over at HomeSeer, it seems someone over there has developed a plug in that reads statuses from the module. (Some information in posts with questions...) The author mentioned he knows how to make it arm/disarm, but hasn't yet implemented it.
Hope that helps!!
Hi skunkiechris,
Thanks so very much. I am going to add this to the list of our requirements. Unfortunately, I cannot commit to any dates but I do consider supporting other devices (thermostats/security systems) one of our top priorities.
Hope that helps!!
  • 11 months later...
Hi John,
Unfortunately not yet and I cannot give you any dates. We are currently working on ELK security module which would make supporting other security systems easier.
Good news I hope to purchase that as soon as available, the holy grail for me ELK integration to get door indications etc for all kinds of neat settings, turning on lights when doors open, turning off AC when windows are not closed, etc etc...
Cheers,
Dan
Hi John,
I have a NAPCO GEMINI panel (Napco is very popular on the east coast). I have an GEM-X10 module which basically lets me send X10 commands based on Arming, disarming, zone breach, alarm etc.
I use the Alarm Panel's X10 signals to trigger scenes, programs and notifications in the ISY. One in particular is my Home Flag. When the system is Armed the flag (KPL Button) is off, System Disarmed Home flag is on.
I'll keep an eye on the progress with the ELK.
I'll add my vote for the Honeywell ICM interface.... I have just recently dived into my Honeywell Vista 15 panel that some security company installed in my house a few years ago, it's a pretty powerful panel once you get your feet wet programming it. I was thinking of adding the ICM unit but, other than email notifications from it on alarm events, it really has no features I need, well, until the ISY will talk to it :-)
I have the Ademco Vista 20P and installed the Ademco 4204 relay module, which is in turn connected to the IOLinc(s). This setup provides basic programmable communication from the Ademco to the ISY.
  • 1 month later...
  • 3 weeks later...
Given that there are many Honeywell Security/VistaICM units out there it would still be advantageous to make this module available for the ISY. There are several services out there that are compatible with this panel's ICM. And adding this to the ISY's capabilities would make it even more competitive. I would glady pay for a module that allows my ISY to talk to my Security Panel. I currently have a LightingICM module that allows me to trigger Insteon scenes based on evens from the security panel. But I would like to be able to control the panel from my ISY and see the system status and event logs.
Hopefully this feature is still in the plan???
thanks,
SLewis
I'd pay also, I have a VISTA ICM and would really like to have it work with my ISY.
  • 1 month later...
thanks,
SLewis
Does ISY support custom module or a software development kit to write your own modules? I just found this today looking for home automation systems that would benifite from my AD2USB device to interface with Vista alarms.
Re
Sean M
  • 7 months later...
Well, took it upon myself to try and control my ADT (Ademco Vista 20P) with Vista ICM module.
Here are a couple of resources I used:
and http://ip.of.vista.icm/cmd_list?cmd=%280.1.2%29Status&auth=0
This is what the keypad of the alarm system looks like:
I can now send keypad commands to the ICM from the ISY from programs - here is one to disarm the system using pin code 1234:
            some condition
       Resource 'ADT Key 1'
       Resource 'ADT Key 2'
       Resource 'ADT Key 3'
       Resource 'ADT Key 4'
You will need a Honeywell/Ademco Vista Panel with the discontinued :( VISTA ICM module (Google tells me that some stores still have some stock) and (of course) an ISY-99i with the Network Module installed.
I'm also willing to share my NetRules file to save you some typing, but don't know how to post it here.
  • 3 months later...
Michel, is there any kind of road map for the security modules?
I have a ademco vista 20p as well, with the AD2USB that connects to my server. Security support is definitely the last missing piece in making this the ultimate home controller.
  • 4 weeks later...
I wonder if the ICM is being discontinued because the vista 20ip and 21ip have it built in? They have built in an internet connection which likely runs the same protocols.
  • 3 months later...
What security systems will Elk control? I've got the Honeywell system but I also have stashed away, some other systems and accessories from adt and GE and others. Is there a list of supported systems or accesories that the Elk works on? I would love to be able to control a home security system with the ISY.
  • 5 months later...
      37.4k
      374.5k
