Z wave Locks
Hmm, shows as $75 for me, in both websites. I can get them slightly cheaper, if anyone is interested, PM me
The module is compatible for real living, and the Zwave+ logo on the image sort of gives it away.
In case there are any doubts...
https://imgur.com/gallery/Tsz5I
And I wouldn't have posted this unless I was sure, the only reason I knew about the module is because I was speaking to Yale directly.
I'll be getting one of the new modules in soon, I'll keep you guys posted...we all know it's not the first time a manufacturer is wrong about their own products.
Edited by cyberk
Sorry you are right about the Z-Wave Plus but...
"Only compatible with Yale Assure Lock"
Edited by giesen
You're absolutely right, but this was a very specific question I asked my Yale Pro rep. But, I will ask again, let's see. Like I said earlier, not the first time we've been given wrong info.
  • 4 weeks later...
Cyberk, were you ever able to get a definitive answer on this?
Nope, I still have not received the module...go figure
  • 1 month later...
fyi
https://community.smartthings.com/t/yale-z-wave-plus-network-module-ayr202-zwv-usa/67535
I never received my module, I'm going to try to get the one that failed from this guy, it all seems kinda weird to me since the modules are built to be independent of the lock, so not sure why he would get an error tone....unless the module is looking for some bluetooth part in the lock, that's not there
  • 3 months later...
Does anyone have experience with or opinion on Baldwin locks, such as this one: http://www.baldwinhardware.com/products/details/door-hardware/keypad-entry/boulder-ac-z-wave-deadbolt-8252-112-ac3
I looked into these when I first installed my Schlage Z-Wave locks, as my home otherwise has all Baldwin conventional locks.  I put the Schlage locks in areas where the look of the locks isn't critical, and I chose them at the time due to availability/proven functionality/cost.  These Baldwin Z-Wave locks are quite a bit more expensive than the Schlage, but IMHO they're cosmetically superior.
Please report back to the forum if you install these.  I have two additional doors that would be candidates for Baldwin locks, as the locks match the door hardware well.
  • 1 month later...
The Baldwin works great. ISY identified it as a "Kwikset Door Lock" and all the settings work fine. There are buttons in Admin Console to Lock, Unlock, Synchronize Clock, and manage Users. Under Users you can add up to 30 codes and set a schedule for certain users. I have not tried out the schedule feature so I don't know if the lock actually has a clock. But Lock and Unlock work fine from Admin Console and OrchestratedMobiLinc.
I bought a "Panic Button" from Aeotec which is a small, single button remote control you can put on keyring. I'm hoping I can get it to unlock the door. Does anyone have experience with this? Maybe I should start a new thread on this. I think it's like a mini-mote with just 1 button instead of 3? From other topics I've read I think I may need to make the Panic Button primary, then include the Baldwin lock to it, then make ISY primary again. I'm not sure I fully understand the implications of making ISY primary vs secondary so if there are some helpful links on this I'd appreciate it.
Anyway the lock works great and looks very nice. I got it in brass finish.
Edited by BILJ
