Wait command not working in a program
Hi all.  Hoping to get some help on a program issue. The purpose of the program is to use the network resource module to announce a warning through my sonos system when motion is detected in my basement. However, despite the fact that I have a wait command after triggering the network resource, each time motion is detected, the announcement gets interrupted and starts over again. Screen shot of the program is attached. Thanks in advance for your help.
Use two programs
Program1
... triggering units send
...call Program2 (if)
Else --
Program2
If --
...Disable Program1
...Do something
...Wait a few seconds
...Enable Program1
Else --
BTW; Your Wait waits for nothing that follows.
and Right click on your program in the program tree and select "copy to clipboard"
That's the expected behaviour. ISY is an event driven system. Any change in the triggering conditions causes the program to abort running an reevaluate (starting again in your case).
You need two programs, as described above.
Edited by MWareman
