Model 2420 Motion Status?
Under the "sensor" current state, my motion always shows ON. Should this be the case or should it only be ON when it senses motion. Sorry for the dumb question, I am having difficulty with my program turning off and thought this might be the problem. Thanks.
Do you have the Motion Sensor to "on only mode"? If so, I believe this would be normal.
In it's normal on/off mode, the motion sensor will send an ON command when it sees motion, then will send an OFF command (which the ISY will show) when there is no motion for a specified period of time (default is 1 minute I believe).
