Access to /USER/WEB
Is there a way to access the web pages from the ISY's Network Module web server via the portal?  Similar in the way that udajax.htm is available via the portal, I would like to get access to /USER/WEB/INDEX.HTM.
Hi mapeter,
You should be able to: go to the Portal and for your ISY, click on Select Tool | Information | ISY Information. The base URL is "URL to ISY" at the end of which you can attach /user/web/xxx.
This said, if your files are JavaScript, you might run into cross-domain issues especially if you use absolute paths.
Thanks Michel, that worked.  Also, thanks for the heads up on the potential cross-domain issues with JavaScript.
