The "Vacation" Button
Here is two ways you can implement an away from home vacation button.
Version 1:
Create a "vacation folder" then set this program to the folder.
   Control 'Vacation Button' is On
And in the rest of your "normal folders" that you don't want to run while on vacation set those folders with this program.
   Control 'Vacation Button' is Off
This will give the least amount of code by only needing the programs to be in folders that will run when the button is on and when it is off.
Version 2:
Create a program call "On Vacation".
To allow triggers to run during Vacation; us this as one of your tests.
   Program 'On Vacation' is True
To prevent triggers from running during Vacation; use this as one of your tests.
   Program 'On Vacation' is False
Any programs that do not have one of the above tests will effectively ignore the Vacation Button.
Toggling the LED:
To control the LED you can: Create a scene and add the KPL "Vacation Button" button to it as a responder, Then you can then turn that scene on/off using ISY Programs, thereby turning on/off the KPL button/backlight. This however does not count as a button press.
How do I "reset" the KPL button?
For example, if I turn on an "Away" button, but I forget to turn it off, a program will run each day at 6am and turn it off for me, so that it doesn't trigger events the next day which check that button's status. (or CONTROL, since it's a weird KPL!)
When I try to set an Action when making a program, the KPL buttons (other than the load) are not options.
~shawn
I don't know if this is the best way to do it, but I created a scene and add the KPL "Away" button to it as a responder, I can now turn that scene on/off using ISY Programs, thereby turning on/off the KPL button/backlight.
I think that is the only way you can do it because the LED on the non-load buttons of keypadlincs only follows scenes.
Sorry I did not provide this answer in the top of this post. I will add that detail at the top for others to find next time quickly.
You can use a Folder condition and put the vacation programs in that folder.
Whenever the 'Keypad A' button is switched On (your vacation button), the 'Vacation' folder will allow programs within it to run up until 6:00AM the next day.
NOTE: The 'is not' part of 'Vacation On' may not work correctly for the current 2.4.9 beta. It will work for the next beta drop.
Folder 'Vacation' (put your vacation programs in here):
Folder Conditions for 'Vacation'
Add conditions to limit when programs in this folder are allowed to run.
       Program 'Vacation On' is True
   And From    Last Run Time for 'Vacation On'
       To       6:00:00AM (next day)
Program 'Vacation On' -- do NOT put this program in Folder 'Vacation'
       Control 'Keypad A' is switched On
   and Control 'Keypad A' is not switched Off
Finally
  • 1 month later...
So to reset the button should we use:
       Time is  6:00:00AM
       Set  Scene 'Vacation Button' Off
within the Vacation On drawer?
And Mark, is 'If Control is On' supposed to be:
       Status  'Family Room KPL 2' is On
   And Control 'Family Room KPL 2' is not switched Off
Thank you,
Rand
  • 7 months later...
Thought I'd try to jump start this topic. I'd be interested to hear what others are using for 'vacation programs'. I'm thinking there would be at least 3 types of programs:
- conserve energy (lower thermostats, etc.)
- simulate occupancy (lights going on at random times, etc.)
- security notifications (email based on unexpected activity, such as motion, door openings, etc.)
For this post, I'll concentrate on randomizing some commonly used lights to simulate someone being home.
Here is a program we might want to use for a young child's bedroom that typically goes to bed around 8pm:
VACATION YOUNG CHILD BEDROOM
       Time is  8:00:00PM
       Wait  10 minutes  (Random)
       Set Scene 'ChildBedroomLamp' On
       Wait  10 minutes
       Set Scene 'ChildBedroomLamp' Off
This would turn on the bedroom lamp between 8:00pm and 8:10pm, and turn it back off 10-20 minutes later. For an older child's bedroom or master bedroom, you might want to adjust the times and/or increase the wait time to simulate typical use.
For a more lived-in room, such as a kitchen or living room, I'm using 2 separate programs since 'turn on' time is more related to sunset, but 'turn off' time is typically still related to time of day:
VACATION KITCHEN ON
       Time is Sunset  + 20 minutes
       Wait  20 minutes  (Random)
       Set Scene 'Kitchen' On
VACATION KITCHEN OFF
       Time is 10:00:00PM
       Set Scene 'Kitchen' Off
This would turn on the kitchen light between 20 and 40 minutes after sunset, and turn it back off between 10:00pm and 10:20pm.
For a bathroom, you might want shorter duration spurts, like this:
VACATION BATHROOM
       Repeat 5 times (Random)
          Wait  1 hour  (Random)
          Set 'BathroomLight' On
          Set 'BathroomLight' Off
This would turn on the bathroom light between 20 and 80 minutes after sunset for between 1 and 10 minutes, then repeat up to 5 times randomly every 1-60 minutes.
I'd love to hear what others are doing!
VACATION KITCHEN ON
       Time is 10:00:00PM
Hi Mike,
These programs look good, but I'd also like to point out how the From/To can be used for this because I think it may not be well understood for most people. By the way, this is just an alternative; having seperate programs is fine.
To clarify
- When the From time arrives, the schedule entry 'Becomes True', When the To time arrives the schedule entry 'Becomes False'
- Then should be thought of as 'Becomes True', and Else should be thought of 'Becomes False'. Therefore the Then runs when the schedule becomes true (the only If condition for this program), and the Else runs when the schedule becomes false.
VACATION KITCHEN ON/OFF
       From    Sunset  + 20 minutes
       To      10:00:00PM (same day)
You could expand this to shut off the lights at 11:30pm + 0-20 minutes on Fri/Sat, and 10:00PM + 0-20 minutes on the other days ...
VACATION KITCHEN ON/OFF with weekends
       On Sun, Mon, Tue, Wed, Thu
    Or On Sat, Fri
       To      11:30:00PM (same day)
Doh! I don't know what I was thinking, I've used the FROM/TO in that manner before.
Thanks for the tip Chris!
Based on Chris' FROM/TO tip, it might be cleaner to change the bathroom program to something like this:
VACATION BATHROOM
       Repeat Every  1 hour
          Wait  45 minutes  (Random)
          Set 'Bathroom' On
          Set 'Bathroom' Off
VACATION BATHROOM
       Repeat Every  1 hour
          Set 'Bathroom' On
          Set 'Bathroom' Off
Hi Mike,
Your original program was fine but you certainly can change it to use From/To as you have done. When using From/To (or in fact any condition that can make your program 'become false') you must take one more thing into consideration. I'll explain it as an example:
1) The program is currently running the Then, and is in the 'Wait 10 minutes (Random)' action
2) 10:00:00PM Rolls around, causing the schedule to become false
3) The Then is stopped, and the Else is run.
In this case, the 'Bathroom' light will remain 'On' because the Then was stopped before it could be turned off.
To prevent this situation, the Else path must do the cleanup:
VACATION BATHROOM
       Repeat Every  1 hour
          Set 'Bathroom' On
          Set 'Bathroom' Off
       Set 'Bathroom' Off
You must consider this type of situation in general. For example, if you decided to use an 'Away button' instead of a Schedule, you would have to do the same thing:
AWAY BUTTON BATHROOM
       Status  'Away Button' is On
       Repeat Every  1 hour
          Set 'Bathroom' On
          Set 'Bathroom' Off
          Set 'Bathroom' Off
Makes perfect sense. The only thing I didn't like about my original program was that the amount of time between sunset and 10pm changes dramatically around here. I prefer fixing the time range with a FROM/TO instead.
Thanks for the clarification!
For security, some people might want the ISY to notify you via email and/or text message if something unexpected happens while in 'vacation' mode. For example, a garage door opening.
If your garage door is Insteon-enabled, you can use the ISY to notify you if it opens. For example:
VACATION GARAGE NOTIFICATION
       Status  'GarageInput1' is On
    Or Status  'GarageInput2' is On
       Send Notification to All
If your garage door is not Insteon-enabled, see this post for a solution:
http://forum.universal-devices.com/view ... arage+door
  • 5 months later...
Version 1:
Version 2:
Toggling the LED:
I'm a beginner, so please forgive me for such a simple question, but I understand the plan for two folders, one for vacation and one for not vacation. But how do I toggle the switch to vacation or not? To be more specific, in version 1, what is "Vacation button" and how do you switch it on / off?
The 'Vacation Button' is any device you want to turn on to indicate that Vacation On is True. I have a button on a keypad that I can use if we have an unplanned away period.
I also use a series of programs for specific dates.
I have one program that checks for the button to be On or any of those programs to be True, thus enabling the Vacation timers.
Rand
