Problems with my ISY994i - Stopped Communicating Last 2 Nights!
I have had my ISY for some time now and I started encountering problems last night! (I am on version 4.3.26)
All of a sudden, last night, the ISY was no longer communicating! The programs stopped working and I couldn't ping the ISY on my network! So I went down and unplugged and then plugged it in again. Similarly, I did the same to the PLM. After a while it started up and everything seemed normal.
Then this evening, the same thing happened again! This time I looked at the ISY LED's and saw that, other than the power light, the only light working was the slow blinking of the memory LED!
I rebooted the ISY again and everything seems normal in that I can access the devices through Mobilinc. For a while, after this latest reboot, I could not get access through the Admin Console - it would start up, allow me to login and then close! After about 15 minutes I was then able to get in through the Admin Console. I quickly made a backup of the ISY since I have made a lot of program changes over the last few days!
Given that I cannot ping the ISY over my home network during these problems I believe that this eliminates the bad PLM issue.
Any thoughts on what is going on or how I debug this?
If you PLM is close to or beyond two years old, then it's time for a replacement.
I don't see your LED pattern in the WIKI page but you may want to look at it for hints.
http://wiki.universal-devices.com/index.php?title=Main_Page#Front_Panel_LEDs.2FLights
You may want to power down the system and reseat the SD Card.
Though I would also suspect any 2413S PLM hardware version below 2.0 and over two years old a highly suspect.
It could be possible the ISY994i is trying to do something with the PLM and it is crashing.
I bought my latest PLM May 25, 2015... that would be significantly less than 2 years!
On the back of the PLM  it shows:
2413S
V2.1
1514
39.00.C2
In the Admin Console it shows:
39.0.C2 v9E / Connected
I had a look at the error log for Tuesday and Wednesday (see attached)... Note that I restarted the system on Tuesday evening at 10:32pm and 11:03pm on Wednesday. I assume that something is amiss if the 'Buffers Free:  0'... right?
Any more thoughts given these error messages?
ISY Error Tuesday and Wednesday.txt
Michel,
I believe you are right about a program that was looping. I fixed the program and I have not seen any errors since.
