Lights on at Sunset or after 5pm
I would like to have some lights to come on 30 minutes before sunset but not before 5pm in the winter.
What is the best way to program this so that it works all year long?
i.e. in the summer 30 minutes before sunset could be as early as 3pm but I don't want lights to come on until 5pm.
In the middle of summer sunset might be at 8pm so I would like the lights to come on at 7:30pm.
Thoughts?
Peter
May take multiple programs.  My quick, brute-force approach, without much thought:
time is sunset -30 minutes
then
run second program (if path)
else
nothing
second program (disabled)
if
time is from 5:00
until 11:59  <<<pick time after latest sunset in your area
then
turn lights on
else
enable third program
third program (disabled)
if
time is 5:00
then
turn lights on
disable third program
You should be able to combine the conditions into one program...I think.
As long as you use time frames. Other event triggers are never true unless they are the centre of attention, so will not work with AND.
...from sunset -30 minutes
...to sunrise next day (thanks Stu)
AND
...from 5:00 PM
then
...turn lights on
...wait 12 hours
... run else below
else
... turn the lights Off
Don't forget to add "next day" to the first time condition or it will never be true B)
Funny how sometimes I get stuck on making complex OR logic when the simple AND logic is what is required.
Many thanks for correcting my simple misdirection.
Yeah the logic can get very complex and you can actually lose strands of hair on your head.
I have some logic I stumble on every time I read it again but I know it works and I have worked it out with paper logic, but still it looks wrong.
The triggers can stretch the strict boolean algebra also with their double purpose, conditional and trigger, from the same statement.
oberkc's logic was my first thought also, but I was just lucky with a sudden idea. I'll brag once you prove it valid, but if it doesn't work...I was never here! :)
