Can Not Restore Firmware After SD Failure
On Thursday, my ISY-994i failed to come back up after a power failure.
I called technical support, and was told that the filesystem had become corrupted. They recommended that I get and install a new SD card, which I have done.
At this time, I am unable to get the unit to accept a restore of firmware. Both the ISY and Admin panel show version 5.0.4 in the "About" tab.
When I try to restore my 5.0.4 back-up, I get a pop-up that says "Upgrade Failed :Invalid or incompatible upgrade file".
I also received a pop up when I first logged in to the ISY that said"Could not open file [/CONF/ELKXPRT.XML] and [/CONF/PORTALS.PSF]"
At this point, I am stuck without a functional ISY.
With phone Tech Support, gone for the week-end, I'm hoping for an expert here with knowledge if this issue.
Problem solved!
With a bit of searching, I found a really old thread from someone having a similar issue a long time ago.
I, like them, was trying to use the "Manually Update Firmware" option under help to load my back-up file.
Once I selected the correct option to "Restore ISY" under the File tab, all was (is) well!
Hi kevkmartin,
Please do NOT forget to also upgrade the firmware.
I did!
I moved to 5.07 without incident (except for the known null scene ON issue)
