Motion sensor low battery notification
GaryK4
I have a program that sends me an email when a low battery is triggered. (send Notification to ...).
This works well, however all I get is the address to the device. Is it possible to add the device name tp the message?
For Z-Wave devices you can use the variable:
${sys.node.#.name} // Device Name
Battery Level is ${sys.node.#.BATLVL} // Current Battery Level
For Insteon devices you can use the variable:
Low Battery state is ${sys.node.#.ST} // The state of the low battery node
If you're running 5.X (Alpha) it will report 0% for OFF and 100% for ON
Hi Gary
Check this link. Depending how your program is set up, you can substitute the name for the address
http://wiki.universal-devices.com/index.php?title=ISY-994i_Series:EMail_and_Networking_Substitution_Variables#Device_Variables_and_Properties
I have a program for each battery device and type the text I want into the notification. Depending how many you have, that may not be workable.
Paul
Information Only: Various Insteon EDOC's indicate the battery percentage can be obtained and displayed to the controller. I am unsure why this important piece of information is never displayed even when its clearly printed as being available for use.
I have monitoring programs for all my motion sensors for the case of low battery, yet I've never received them. Can anyone share their program so I can see what I've been doing wrong?
Here is an example
Battery Motion Sensor Driveway - [ID 001A][Parent 0019]
        Control (Old) 'Zystem / Battery Alerts / Driveway Motion-Sensor-Low Ba' is switched On
        Resource 'Pushover ISY Log - Driveway MS Battery'
It says "Control (Old)" because I am V5.04... If you are on V4, use "Control".
Paul
Here is an example
Paul
Hi Paul..
 Just wondering.. are you using resource because it is a 99i?
Stan
Hi Stan
No, I've only owned a 994i.  The resource is used because over time I changed from using text/email notifications (which I believe the 99i supports) to the Pushover notification app. It integrates all messages as a single log, or organized in groups (HVAC, Sprinkler, Alarm, garage, etc notifications). I communicate with Pushover via the internet using a REST API call that can only be done via a Network resource
Paul
Edited by paulbates
Hi Stan
No, I've only owned a 994i.  The resource is used because over time I changed from using text/email notifications (which I believe the 99i supports) to the Pushover notification app. It integrates all messages as a single log, or organized in groups (HVAC, Sprinkler, Alarm, garage, etc notifications). I communicate with Pushover via the internet user a REST API call that can only be done via a Network resource
Paul
 Hey Paul,
 Wow.. OK..  I am soo behind .. just when I think I'm getting a handle on some things something new with options and features like this bubbles up and my mind must know more. Guess I just have to keep spending time here reading & searching for a long while :) ..
Best,
Stan
 Hey Paul,
Best,
Stan
Stan
I watched others use it, spent some time learning it and gradually switching over. The good news is that its all the same alert programs in my ISY, Its a matter of where I send a notification.
You can look at the pushover app and decide if you like it. There are a number of competing apps as well. Here is the 'how to' from the wiki
https://wiki.universal-devices.com/index.php?title=ISY-99i_Series_INSTEON:Networking:Mobile_Notification
Paul
Stan
Paul
Thanks again Paul..
Was looking at the apps but looking at setting up the ISY seems more complex. I was just looking into it under resources and tried to see if the manual provided some insight on configuring but looked like it just gave app info. I'll do a little more homework but very interested in this if I can get instant notices and separate from email. Sometimes that gets overwhelming and don't want to see it mixed in with my normal mail.
Best,
Stan
Thanks again Paul..
Best,
Stan
Stan
That's exactly why I did it. When I used email I'd have outlook.com file the messages in special folders, but then there was not an easy way to see all log activities in event order. The app has special notification sounds for different messages. It took some patience for the first one.. but after you get the first one figured out, the remaining ones are copy and paste, more or less.
Paul
      378.7k
