Schedule issues
Hello, new user here.
I wrote a simple program to turn on a lamp when either of two entry doors are opened and would like to add a condition so it only works from sunset to sunrise the next day (no sense turning on the lamp during the day). I thought that simply adding a schedule to the if statement would do it, but no dice. The program acts as it did before, ignoring the schedule. What am I doing wrong?
Thank,
Tom
Living Room Lamp - [iD 0002][Parent 0001]
        From    Sunset
        To      Sunrise (next day)
    And Status  'Computer Room Door' is On
     Or Status  'Front Door' is On
        Set 'Living Room Lamp' On
        Wait  5 minutes
        Set 'Living Room Lamp' Off
Hi Tom,. and welcome to the forums!
Its related to order of precedence. All you need to do is use the "Add and" function in the Admin console, lower right of the program window.
        From    Sunset
          and (
Paul
Edited by paulbates
Probably going to need some parenthesis.
        From    Sunset
    And {Status  'Computer Room Door' is On
That fixed it!
I thought about parenthesis and looked at the command, but couldn't figure out how to implement it. Now that I look at the user guide specifically for parenthesis, I see it's pretty well explained. Is there a good source of example programs somewhere that I can refer to for help in learning the programming?
Paul, I was just in your neck of the woods last week for a burger at Millers Bar. Best burgers in the state!
Thanks for the help, guys.
Tom
Edited by TomG
