apostolakisl Posted January 17, 2017 Posted January 17, 2017 James, I am a bit frustrated by the slow loading of the Elk portion of Agave. Typically I just want to quickly arm the system and have to wait for what seem like an eternity as the "refreshing data" thing is happening. I'm not sure what "refreshing data" is, perhaps it is loading all the outputs, zones, etc? Perhaps there is a way you can have it just load in sections, maybe first it loads your favorite keypad and opens it up for use while in the background it keeps loading the other stuff? Great program you're putting together either way.
Blackbird Posted February 11, 2017 Posted February 11, 2017 I was about to comment about load times as well. Mine takes about 27 seconds every time to refresh the data on elk. Any idea if this can be fixed
James Peterson Posted February 14, 2017 Posted February 14, 2017 James, I am a bit frustrated by the slow loading of the Elk portion of Agave. Typically I just want to quickly arm the system and have to wait for what seem like an eternity as the "refreshing data" thing is happening. I'm not sure what "refreshing data" is, perhaps it is loading all the outputs, zones, etc? Perhaps there is a way you can have it just load in sections, maybe first it loads your favorite keypad and opens it up for use while in the background it keeps loading the other stuff? Great program you're putting together either way. I was about to comment about load times as well. Mine takes about 27 seconds every time to refresh the data on elk. Any idea if this can be fixed working on that.
apostolakisl Posted February 20, 2017 Author Posted February 20, 2017 Just downloaded an update. Elk pops up instantly now. Nice. Just for my knowledge, does this mean that it might not be showing correct info right at first?
James Peterson Posted February 20, 2017 Posted February 20, 2017 Correct. But the update is now happening in the background. Sent from my Nexus 5X using Tapatalk
apostolakisl Posted February 20, 2017 Author Posted February 20, 2017 Correct. But the update is now happening in the background. Sent from my Nexus 5X using Tapatalk OK. But if I hit the arm button, this still responds right away?
apostolakisl Posted February 20, 2017 Author Posted February 20, 2017 Also, might consider adding a version check or something. Seems like I have to go to the google play store to check for updates manually.
James Peterson Posted February 20, 2017 Posted February 20, 2017 OK. But if I hit the arm button, this still responds right away?Yes. It should be more behind the scenes updating from now on. You can still request a full update by long pressing on the top left shield as always thought. This is just in case there are issues. Sent from my Nexus 5X using Tapatalk
apostolakisl Posted February 20, 2017 Author Posted February 20, 2017 Still hoping for a multi-window view. I would love it if you could have things like Elk keypad, Insteon scenes, and a thermostat all up at once. This would be perfect for wall mounted tablets. Adding audio system support would make it a 100%. Perhaps too many audio systems out there, I don't know.
