KeypadLinc 2334-2 missing A,B,C,D buttons in ISY99i/IR Admin Console
Hello All,
I recently installed a KeypadLinc 2334-2 and paired it with my ISY 99i/IR although I cannot see the A,B,C,D buttons in the Administrative Console.  I've successfully installed te KeypadLinc 2486D in the past and do not seem to have the same issue.
Could someone please help me understand why this is not working.
Thank You
Click on the + to the left of the KPL.
@Stusviews - I do not have that option
If you click on the KPL is there a set of options (at the bottom) that includes Buttons Grouping and Buttons Toggle Mode?
That certainly indicates that it's a KPL. And your KPL does not have a + to the left as these do?
Edited by stusviews
Is it possible that the 99i and/or the older UI doesn't support the firmware in the current KPL's?
Yes, it's likely.
Many of the presently sold Insteon modules are too new for the last released ISY99i firmware. 3.3.10
Your new module maybe too new and not supported.
I believe the UDI ISY99i to ISY994i upgrade is still available.
Edited by Brian H
Where do I find the ISY99i to ISY994i upgrade?
Thank you all very much.  I should have guessed it required an upgrade.
