Honeywell Thermostats?
So I upgraded to the ISY Portal and the dashboard has a window for thermostats.  Are Honeywell Total Comfort wifi thermostats compatible or only INSTEON/z-wave?
Honeywell WiFi thermostats are not ISY compatible.
Why this is "technically" true there is a work around. If you have the portal you can use IFTTT with your Honeywell TStats. [emoji3]
There is also integration with ISY V5 Firmware and Nodelink... that requires an external light windows or linux server. It can be used in combination with IFTTT
http://forum.universal-devices.com/forum/116-honeywell-tcc/
Paul
Was that link the in ended one? I only get a short discussion on x XML.
Sent from a tiny keyboard. Response may be brief.
If it helps..There is a Amazon skill for it that you can link with the portal so you can voice control it.
The skill only has the ability to change the temperature. You can't change the mode nor turn the thermostat off. And if it's off, then you can't turn it on by voice.
