Error led blinking
I have been using the ISY for a couple of weeks and keep getting the led Error blinking; twice in the last couple of days. The users guide says "A blinking ERR LED indicates a file system error. Please power off the ISY and try to re-seat the SD card. If that does not help, the SD card may be defective." I don't seem to have an SD card; plugging & unplugging solves the problem. Am I supposed to have an SD card? :?:
The later ISY99i models and all the ISY994i models have a SD card slot on the front. Where you pop off a small cover on the front panel to access it
The original ISY99i you have to take the top cover off. As the link Stu provided shows.
Been awhile since I change my ISY99i SD card for a larger capacity one. Mine was an older cover model. Where I had to take the cover off. My ISY99i had a SD card sized socket and mine was a SD Card. I believe some ISY99i units had a micro SD card in a micro SD to SD card adapter. In the SD card socket.
My ISY994i has a micro SD card.
Edited by Brian H
Thanks for the information. I was able to see the card with the help of a magnifying glass. :mrgreen:  It looks like a a micro SD card. Thanks again.
