How to replace a KPL and not have to reprogram???
I have never had to replace a KPL before but have to now.  What is the proper procedure so I can keep all of my settings from the old one?  What are some things I will need to do if I have the old one in scenes?  Where can I find a tutorial on this?  Thanks.
Add the new KPL to the system than right mouse click and use the replace with. The new KPL should be listed as one of the available option keeping in mind it must be the same type: Dimmer vs Relay.
Once the system has successfully replaced the KPL it will delete the *New* KPL and replace it with the existing KPL name.
What if I have the old one in scenes in the main listing?  Do I have to name the new one first?
Do not rename the newly added device. Once the replacement is completed, the new device will have the name of the replaced device and will also be correctly added to scenes and programs. The ISY will shut down, you'll need to restart and wait until the ISY is not busy (look at the lower left corner). The only indication that the replacement occurred will be the new device's Insteon ID.
The old device should be removed from any folder it's in before you can use the replace function.
No, only if the main device is (IN) a folder. A device in a scene is not considered in a folder.
The highest calling in life is to serve ones country faithfully - Teach others what can be. Do what is right and not what is popular.
