Read New Insteon Device Addresses Carefully!
I recently went through a very long and painful troubleshooting session with a new Insteon switchable outlet.  I tried to link it with my ISY controller and it would not respond.  I reported the failure and got another outlet and it behaved the same way.  I finally tried Link Management->Start Linking and put the outlet in linking mode.  The controller discovered it, but with a different address than the one I entered.  I had entered the address on the outlet, 44.88.23.  The ISY had discovered 44.08.23.  I got out a flashlight and a magnifying glass and sure enough, the label said 08 and not 88, but for some reason the bizarre font they've switched to puts a dot in the middle of the zero that makes it look like an eight unless you look VERY closely.  See the attached pictures.
I hope this helps others who might run into the same problem.
By the way, the second outlet also had a zero in the address that looked like an eight!
Thank you for the information.
From time to time. We have had others misread a digit. I have a few of the Remotelinc 2 modules where the six digit ID is poorly printed and I misread one myself.
It almost looks like the Zero has a dot in the middle and not quite the same shape but unless you happen to have a real eight in the ID for comparisons. It would be hard to catch.
That sticker is completely different than what has been used in the past.
The highest calling in life is to serve ones country faithfully - Teach others what can be. Do what is right and not what is popular.
