Trigger lights on motion at 11pm, before 11pm, keep on
Hello, I am trying to figure this out. I have 4 outdoor lights on the following schedule:
Front Porch Light - [iD 0004][Parent 0001]
        From    Sunset
        To      11:00:00PM (same day)
        Set 'Outdoor: Front Porch Light' On
        Set 'Outdoor: Front Porch Light' Off
Garage Outside Lights - [iD 000A][Parent 0001]
        From    Sunset
        Set 'Outside: Garage Lights' On
        Set 'Outside: Garage Lights' Off
Garden Patio Light - [iD 0005][Parent 0001]
        From    Sunset
        Set 'Outdoor: Garden Patio Light' On
        Set 'Outdoor: Garden Patio Light' Off
Walkway Lights Schedule - [iD 0015][Parent 0001]
        From    Sunset
        Set 'Outdoor: Walkway Lights' On
        Set 'Outdoor: Walkway Lights' Off
So each of these 4 devices will turn ON at sunset and off at 11pm
I also have a motion sensor setup. I want the motion sensor to turn these lights on upon motion, starting at 11:05pm until sunrise and go off after 5 mins if triggered on motion.  However, I am finding this schedule isn't working:
Outdoor Lights Motion - [iD 0013][Parent 0001]
        From    11:05:00PM
        To      Sunrise (next day)
    And Status  'Driveway Sensor-Sensor' is On
        Wait  5 minutes
Any thoughts on the programming here? It seems my last "else statement" is overiding and keeping the lights off from sunset to 11pm.
Edited by jam583
Here is what I have doing something similar in a scene.. Maybe the concept will work for yours with the devices?
Hallway Auto Light - [iD 0021][Parent 0001]
        From    Sunset  +  1 minute
        To      Sunrise -  1 minute (next day)
    And Status  'Front-Door / Front Door-Opened' is On
        Set Scene 'Hallway Auto Light' On
        Wait  2 minutes
        Set Scene 'Hallway' Off
Have you tried not including any Else statements in the MS program? Also, why not use one program for the outside lights?
I don't see any reason why a single program would not work for your schedule.  If you don't want to use a scene as sdynak suggested, try:
        From    Sunset
Regarding the motion sensors, I expect your program should work with one minor modification:
        From    11:05:00PM
    And Control 'Driveway Sensor-Sensor' is On  <<<change to "control" rather than "status"
        Wait  5 minutes
Ok, so I set 1 program up for the lights from sunset to 11pm:
Outdoor Light Schedule - [iD 0004][Parent 0001]
        From    Sunset
For the motion, I changed it to control, as mentioned:
        From    11:00:00PM
    And Control 'Driveway Sensor-Sensor' is switched On
        Wait  5 minutes
Look good? I'll monitor and see how it looks tonight.
You don't need the Else in the MS program.
I actually like the else clause. This guards against the possibilty when sunrise occurs during the 5 miunte wait period. Without the else clause, the lights would remain on.
Ok .. so I came home tonight, all the lights were on. It appears, for some reason, they cut off once I pulled into the driveway. Doesn't make any sense as the motion sensor isn't supposed to kick on until 11pm .. I've reviewed what I've pasted in this and it seems as if it all should work and many have said it looks right as well. Perhaps anyone else have any insights?
Well, your first program turns them on at sunset and off at 11. What time did you arrive home?
Did you create any scenes that include the motion sensor (controller) and lights (as responder)? If so, delete the scene.
Edited by oberkc
They were on but turned off it seems when the MS detected me, even though the MS shouldn't go into effect until 11pm. The MS isn't connected to do anything else, other than send an email on detection.
I may also have to apologize to you. I think I gave you bad advice. I thought simple motion programs could be handled in a single program, but may even have to break it into two programs (pretty common solution).
For your motion program, try the following approach:
Time is from 1100
To sunrise (next day)
Run next program (then path)
Nothing
Next program:
Nothing
Turn all the lights on
Wait 5 minutes
Turn all the lights off
Nothing
Time is from 1100
Nothing
Next program:
Nothing
Wait 5 minutes
Nothing
I don't follow on the motion program. Currently, it's set as:
        From    11:00:00PM
        Wait  5 minutes
What do you mean run next program, then path?
Break it into two programs.
Program 1
        From    11:00:00PM
then
       run program 2 (then path)
else
nothing
Program 2
if
nothing
then
        Wait  5 minutes
else
nothing
When one calls a program from another program, one must specify what part of the program to run.  In this case, I want it to run the "then" path.  (Not the IF path.  Not the ELSE path.)
Ok, it's setup as follows now:
        From    Sunset
MOTION SENSOR
        From    11:00:00PM
        Run Program 'Outdoor Lights Motion Prog' (Then Path)
AND
Outdoor Lights Motion Prog - [iD 0005][Parent 0001]
        Wait  5 minutes
OK.  Hopefully, I did not give you bad advice this time.
As I asked before, also, make sure your motion sensor is not in any scenes.
Hi, first make a troubleshoot, trying to setup the program part by part. Add a line and try. Maybe you can try configuring a scene with MS and switches, then MS set to On Only and Night only modes, then program a short timer for the day and 5mins timer after 11:00pm.
Enviado desde mi iPhone utilizando Tapatalk
jam583, are the programs working the way you want?
