Please help with simple program (hidden door sensor turning on lights for 10 minutes)
Here is my current program
status "entry door sensor" is on
Set scene "hall light switch" on
Wait 10 minutes
Set scene "hall light switch" off
What happens is the lights will come on but never turn off. I have same problem with similar program with garage door sensor and lights so I am sure I am just doing it wrong. It seems as soon as i close door after opening it kills the program so never completes.
thanks
Does the light turn off if you don't close the door? Are the sensor and hall light members of a scene?
Rather than "status" as a condition, use "control".
Control "entry door sensor" is turned on
Same.....
IF it helps here is something that works for me in a similar arrangement .. for some reason the else statement makes some difference which I got from similar suggestions here.
Hallway Auto Light - [iD 0021][Parent 0001]
        From    Sunset  +  1 minute
        To      Sunrise -  1 minute (next day)
    And Status  'Front-Door / Front Door-Opened' is On
        Set Scene 'Hallway Auto Light' On
        Wait  2 minutes
        Set Scene 'Hallway' Off
The problem with your program is that when the door is closed the status of the door sensor changes which causes the program to start again from the beginning. Since the door is closed the "else" portion of your program is executed. Since it's empty, it just ends.
If your door sensor is an Insteon device you can use the "if control" statement as mentioned above. If it is a Z-Wave sensor then you'll need two programs:
if
   Status "entry door sensor" is on
then
   Run Program "turn light on" (if or then)
else
if
then
   Set Scene "turn hall light" On
   Wait 10 mins
   Set Scene "turn hall light" Off
else
I would have thought that if the door is closed you'd want the light off anyway, in which case you can simply turn the light off in the "else" clause.
   Wait 10 minutes
Edited by andyf0
Thanks for the replies everyone. Using "control" worked.
