INSTEON 74551 GARAGE DOOR CONTROL & STATUS KIT
Hello
I'd like the garage to stay on for 5 minutes after the garage door opens and then turn off so, I've created the program below. The problem is that the light comes on when the door opens but doesn't turn off. The events are door opens; light comes on; door closes; light continues to stay on indefinitely. Any ideas?
     Status "Garage Door-Sensor' is On
     Set 'Garage Near' On
     Wait 5 minutes
     Set 'Garage Near' Off
John
Hello John,
Is the light from the GDO unit motor or a light fixture attached to the home?
The problem is that when "Garage Door-Sensor' changes status to Off while the wait is in progress;  this event immediately causes the program to be re-evaluated.  Because it is false, it stops the wait and the program is ended before it can get to the "Off" command.
Here's a quick-and-dirty workaround to ensure the light gets turned off:
     Wait 5 minutes
     Wait 5 minutes
There are cleaner ways to accomplish exactly what you want, but all the approaches I know of require creating a second program.
Edited by KeviNH
I think KeviNH nailed the problem.  There may be an alternative solution to the "second program" approach.
Try using "control" rather than "status" for the garage door sensor condition.  (Suggested ELSE path not needed.)
Thank you all so much. I noticed today that when the GD was left open that the light went off after 5 mins so that reinforced the idea that the wait was being interrupted by the close. I changed "status" to "control" as per oberkc and that did the trick
