Triggers in the ISY
Just a possible enhancement, it would be nice to be able to define device/scene/program triggers in the admin console instead of the portal. Then the portal you could simply check them on/off or even have all of them work automatically.
I'm certain I'm going to switch to Google Home when it comes out, and keeping the triggers associated with the ISY instead of the portal will allow one to use both systems without duplication of setup. Personally I find it preferable as this would follow the depndency injection software pattern.
I'm not sure what you are trying to say. You can certainly "trigger" a device or scene from the Admin Console as well as running Then or Else in a program. And the portal allows you to "trigger" a device, scene and/or program (Then or Else) using your voice.
