INSTEON® Keypad Dimmer Switch, 6 and 8-Button
So my Insteon 8 button switch is acting strange. I have done a reset etc.. there are times when the switch will turn on and off a light for several minutes. Is the switch going bad?
Insufficient data to be conclusive.  Assuming that there are no programs involved, and no scenes, and no spurious signals from other gadgets in the house, and that the load is compatible and that it is wired correctly, yes, it is possible that the switch is failing.
No programs, yes to scene. New gadget Alexa (Alexa turn on dinning table). Load correct and wired perfectly. Dinning table button, so far is the only button that will cause the dinning table light to ramp up and down.
It sounds like the problem appeared since configuring in ISY Portal / Alexa?
If yes, un-configure the switch in the ISY portal from Alexa and see if the problem goes away.
Paul
  • 3 weeks later...
      37.6k
      376.2k
