Can it work with voxcommando?
Hi, after seen this videos I am wondering if ISY could integrate with voxcommando
http://voxcommando.com/home/features/
it say Flexible API - VoxCommando doesn’t just talk to other programs, it listens too. Other programs can send messages to VoxCommando via UDP, HTTP, TCP, or command line that trigger events or execute actions. You can even host a simple web server.
If it can send using HTTP, then it can set send commands to ISY using the REST API.
If it has an HTTP API, then the ISY can send commands to the VoxCommando. You will need to purchase the Network Module.
(No Network Module needed for REST API - already included with base configuration.)
