New Skill
Today I noticed that alexa can control my Trane Comfortlink thermostat, she found it by herself when I was discovering devices on my ISY.. She never saw it before, but cool!
Set to a specific temperature:
“Alexa, set my (thermostat name) to (72) degrees”
“Alexa, set (thermostat name) temperature to (72)”
“Alexa, set (thermostat name) to (72)”
“Alexa, set[or raise, or lower, or change] my (thermostat name) to (72)”
“Alexa, change temperature to (72)” Alexa will ask which device, say the thermostat name.
“Alexa, turn temperature to (72)” Alexa will ask which device, say the thermostat name.
“Alexa, raise temperature to (73)” Alexa will ask which device, say the thermostat name.
Raise the temperature a set amount:
“Alexa, raise[or increase] the (thermostat name) by (4) degrees”
“Alexa, raise[or increase] the (thermostat name) temperature by (4) degrees”
Increase the temperature by 2 degrees:
“Alexa, heat my (thermostat name)”
“Alexa, increase the (thermostat name) temperature”
“Alexa, heat up (thermostat name)”
"Alexa, make it warmer in the (thermostat name)"
Lower the temperature a set amount:
“Alexa, lower[or decrease] the (thermostat name) by (4) degrees”
“Alexa, lower[or decrease] the (thermostat name) temperature by (4) degrees”
Decrease the temperature by 2 degrees:
“Alexa, lower the (thermostat name) temperature”,
“Alexa, cool down (thermostat name)”
“Alexa, make (thermostat name) colder”
Edited by MarioLanning
Which model t stat do you have ?
Robert
