"Copy Scene Attributes" programatically?
I want to change the ramp rate of some lights for all switches in a virtual 4-way light based on some conditions.
I can use a program with "Set Scene" to change the ISY based scene to have a new ramp rate but I would like to automatically "Copy Scene Attributes" to the switches involved.
For the non-load switches I could use an ISY trigger to initiate the scene with the desired ramp rate but that leaves the load switch still functioning with a different ramp rate and I would rather have the ISY push all new ramp rates and use insteon links instead of hopping through the ISY if possible.
If I go to each switch involved and "Copy Scene Attributes" after the program updates the ISY scene then this is the functionality I am looking for, I just want it automated each time that condition is met.
Hello tazal,
I am so very sorry for a tardy reply ... for some reason I had not noticed your post.
Thanks so very much for the feedback ... I shall have this added to our todo list but I must also let you know that it will have a very low priority.
No problem on the delay, I know you're busy. :-)
I didn't know if there was something I was missing or not, I just got my first ISY recently, so far so good!
Hello tazal,
:D:D
