Will a long-running program be stopped by a program change.
I have a program that turns on the water in my birdbath for 10 seconds, hourly.
Daily Bird Bath Auto-fill
        Time is 6:00:00AM
        Repeat 13 times
           Send X10 'J2/On (3)'
           Wait 10 seconds
           Send X10 'J2/Off (11)'
           Wait 59 minutes and 49 seconds
        Wait 10 seconds
If I make a change to that program during the 13 hour cycle, will that cycle be interrupted?
JLOB
        Time is 6:00:00AM
        Repeat 13 times
           Wait 10 seconds
        Wait 10 seconds
JLOB.
Whatever is in the "then" clause at 6:00 is what will be executed. If you make changes in the "then" clause the program could be interrupted and will start again at the next 6:00 am cycle unless you manually run the "then" clause after you make changes.  What change did you want to make?
Actually I just wanted to change the start time.  Guess it'll be ok.  Thanks.
J.
What is the purpose of the "else" clause?  Perhaps you have a different program that calls the else clause of this program, but as it sits here, the else clause has no trigger.
Bingo.  Another program triggers the water for a one-time 10 seconds.
JLOB
I don't understand this. If the time is not 6am, the else clause should be executed. But it sounds like this is not the case.
At 6 am the "then" clause runs.
The following will run the else clause at 6am
        Time is not 6:00:00AM
That's because your original statement indicates what to do when it's 6 am. It doesn't state what to do if the time is not 6 am. Nothing is assumed. That's why apostolakisl's suggestion needs to be added.
