I'm Just Confused?!?!
** SOLVED **
Hi All,
I setup an Autelis controller for my Jandy Pool system and all is working fine after adding the commands to the network resources page.  However I am struggling with how to use the network resources.  Here is what I want to do.
I want use the Amazon Echo to control my pool equipment (waterfall, spa jets, lights, etc..)
I configured the network resources and tested each one and no issues.
I have also set up a variables page with every piece of connected equipment that the Autelis can talk to.
So this is where I am stuck.  I know I can control a scene with the Echo.  However the scene needs a device to be in the scene to control.
I as hoping to setup a program that detected the variable change and would run the corresponding network resource.  But I can't figure out how to set the variable without an actual device?
Any help pointing me in the right direction would be much appreciated..
Rob
I am embarrassed that I figured this out quickly after I posted.  I did not see the option when configuring the ISY to work with the Echo that there was a devices, scened, or Programs tab.  If I would have seen the program tab i would have got it quickly.  It woks fine now!
Thanks for taking the time to read the post!
  • 1 month later...
Hi,
I also have a Jandy pool (Iaqualink) do you control your devices by echo?  How are you doing that?
Rich
