autoperformance Posted July 18, 2017 Author Share Posted July 18, 2017 Are you using a dimmer switch to turn on a buzzer? What model switch and what model buzzer are you using? I use this http://www.smarthome.com/insteon-2663-225-on-off-outlet-light-almond.html with this :http://www.ebay.ca/itm/LZQ-401K-DC-12V-24V-80mA-Electronic-Alarm-Buzzer-Siren-120db-57x-45-x-40mm-/272711764543?hash=item3f7ee34a3f:g:cC8AAOSwLsBZPIiG since I put the repeat before the alarm repeat twice. What I need it's the alarm can only start 1 time each 120 secondes. Thank you Link to comment Share on other sites More sharing options...
Techman Posted July 18, 2017 Share Posted July 18, 2017 I use this http://www.smarthome.com/insteon-2663-225-on-off-outlet-light-almond.html with this :http://www.ebay.ca/itm/LZQ-401K-DC-12V-24V-80mA-Electronic-Alarm-Buzzer-Siren-120db-57x-45-x-40mm-/272711764543?hash=item3f7ee34a3f:g:cC8AAOSwLsBZPIiG since I put the repeat before the alarm repeat twice. What I need it's the alarm can only start 1 time each 120 secondes. Thank you Your alarm appears to be 12 or 24 volts. What are you using to reduce the voltage as that could be creating noise on the powerline and interfering with the Insteon signal Link to comment Share on other sites More sharing options...
autoperformance Posted July 19, 2017 Author Share Posted July 19, 2017 Your alarm appears to be 12 or 24 volts. What are you using to reduce the voltage as that could be creating noise on the powerline and interfering with the Insteon signal Yes it's a 12 volts alarm. But the power supply is connected to the Insteon Remote Control Dual On/Off Outlet. So the if the outlet is not powered, the power supply is not powered too. Maybe that could cause power off signal problems, both not power on. There is a way to see all the communication between device and know exactly where is the problems ? I'm a little bit tired of this problem. There always problem here and there with this system. Everything work fine and suddenly nothing works anymore. Thanks for your help. Link to comment Share on other sites More sharing options...
Techman Posted July 19, 2017 Share Posted July 19, 2017 Yes it's a 12 volts alarm. But the power supply is connected to the Insteon Remote Control Dual On/Off Outlet. So the if the outlet is not powered, the power supply is not powered too. Maybe that could cause power off signal problems, both not power on. There is a way to see all the communication between device and know exactly where is the problems ? I'm a little bit tired of this problem. There always problem here and there with this system. Everything work fine and suddenly nothing works anymore. Thanks for your help. Try doing a diagnostics on the outlet. Right click on the device name Click on Show Device link table After the table populates Click on Compare If it shows any mismatched links then Do a Restore Device which will rewrite the links to the device. Link to comment Share on other sites More sharing options...
