Event viewer/manual vs program query
I am a newbie. I was writing some programs for my thermostat today and observing the event log. I noticed some strange behavior which I wanted to validate: when I run a query manually vs. programmatically the event log shows different results.
The simple program below is intended to query the thermostat every 15 minutes.
       From    12:00:00AM
       For      24 hours
       Repeat Every  15 minutes
          Set 'Movie thermostat' Query
The log file below shows what happens when I query the thermostat manually at 15:46:36 vs. run the program at 15:46:44. The query run manually seems to show the climate values returned by the thermostat, whereas the query run programmatically seems to omit the climate values. I don't know if the event log is just supressing the values or if they are not being received.
2009/03/01 15:46:36 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 00 06 (00)
2009/03/01 15:46:36 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 80 (80)
2009/03/01 15:46:36 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:36 : [ 11 95 BC 1] ST 128
2009/03/01 15:46:36 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 20 06 (20)
2009/03/01 15:46:36 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 82 (82)
2009/03/01 15:46:36 : [ 11 95 BC 1] CLISP 130
2009/03/01 15:46:36 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 60 06 (60)
2009/03/01 15:46:37 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 17 (17)
2009/03/01 15:46:37 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:37 : [ 11 95 BC 1] CLIHUM 23
2009/03/01 15:46:37 : [iNST-ACK ] 02 62 11.95.BC 0F 6B 02 06 (02)
2009/03/01 15:46:37 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6B 01 (01)
2009/03/01 15:46:37 : [ 11 95 BC 1] CLIMD 1
2009/03/01 15:46:37 : [iNST-ACK ] 02 62 11.95.BC 0F 6B 12 06 (12)
2009/03/01 15:46:38 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6B FF (FF)
2009/03/01 15:46:38 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:38 : [ 11 95 BC 1] CLIFS 255
2009/03/01 15:46:44 : [ Time] 15:47:00 0(0)
2009/03/01 15:46:44 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 00 06 (00)
2009/03/01 15:46:44 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 80 (80)
2009/03/01 15:46:44 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:44 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 20 06 (20)
2009/03/01 15:46:45 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 82 (82)
2009/03/01 15:46:45 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:45 : [iNST-ACK ] 02 62 11.95.BC 0F 6A 60 06 (60)
2009/03/01 15:46:45 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6A 17 (17)
2009/03/01 15:46:45 : [iNST-ACK ] 02 62 11.95.BC 0F 6B 02 06 (02)
2009/03/01 15:46:46 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6B 01 (01)
2009/03/01 15:46:46 : [standard-Direct Ack][11.95.BC-->ISY/PLM Group=0] Max Hops=3, Hops Left=1
2009/03/01 15:46:46 : [iNST-ACK ] 02 62 11.95.BC 0F 6B 12 06 (12)
2009/03/01 15:46:46 : [iNST-SRX ] 02 50 11.95.BC 0F.45.2A 27 6B FF (FF)
Hello ncarney,
Yes, this is true:
1. When you do a manual query, ISY clears all the previous states and thus, regardless of the change, you will get an event
2. When you do a program query, ISY does not clear the previous states for the device and thus you will only get an event for states that have actually changed from the last time
