Device Link Table appears corrupt
Hi,
its been a while since I've needed to post on the forum as everything in my setup has been pretty stable for the last 18 months. This weekend however I have noticed that I have not been able to remotely control one of my Dimmers (2477D-SP Dual Band Switchlink Dimmer).
BTW I'm on version 4.5.4
I to a look at the device links table and it appears to be corrupted. It looks something like this:
0 : 0FF8 : F8 F9 FA.FA.FC FD FE FF
1 : 0FF0 : F0 F1 F2.F3.F4 F5 F6 F7
2 : 0FE8 : E8 E9 EA.EB.EC ED EE EF
3 : 0FE0 : E0 E1 E2.E3.E4 E5 E6 E7
31 : 0F00 : 00 01 02.02.04 05 06 07
When I list out the ISY link table it shows what I would expect (just the inks to the PLM):
0 : 0FF8 : A2 00 30.6A.65 FF 1F 01
1 : 0FF0 : E2 01 30.6A.65 01 00 01
2 : 0FE8 : 00 00 00.00.00 00 00 00
So I thought easy problem to solve just do a "Restore Device". Unfortunately this didn't work. From the log it says its writing the correct values but it doesn't seem to have updated the device.
Using the Admin console Its possible to trun the device on and of, quers it etc. HOWEVER, looking at the power drain reported by my GEM the commands are not actually turning the lights on/off - they appear to be permanently ON  :cry:
So I thought lets delete the device and re-add it selecting the option to delete the link table when adding. First thing was that it couldn't determine the type of device automatically - I had to select it manually. It then added the device just fine. Looking at the device link table again it still contained all the rubbish values. Trying a restore on the newly created device also did not work.
I have the feeling that I have another failed switch.
Has anyone any ideas on how I could reset this (remotely - I have no physical access to do a hard factory reset)?
Strange thing is that I can query the device and it reports back the status.
Sat 08/12/2017 07:34:01 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 19 00
Sat 08/12/2017 07:34:01 : [iNST-ACK    ] 02 62 23.D5.8D 0F 19 00 06          LTSREQ (LIGHT)
Sat 08/12/2017 07:34:01 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 19 00    LTSREQ (LIGHT)
Sat 08/12/2017 07:34:01 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:34:01 : [D2D EVENT   ] Event [23 D5 8D 1] [sT] [0] uom=0 prec=-1
Sat 08/12/2017 07:34:01 : [  23 D5 8D 1]       ST   0
Sat 08/12/2017 07:34:01 : [D2D EVENT   ] Event [23 D5 8D 1] [OL] [255] uom=0 prec=-1
Sat 08/12/2017 07:34:01 : [  23 D5 8D 1]       OL 255
Sat 08/12/2017 07:34:01 : [D2D EVENT   ] Event [23 D5 8D 1] [RR] [30] uom=0 prec=-1
Sat 08/12/2017 07:34:01 : [  23 D5 8D 1]       RR  30
This is what I get if I query the "Insteon Engine":
Sat 08/12/2017 07:37:07 : [All         ] Writing 1 bytes to devices
Sat 08/12/2017 07:37:07 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 0D 00
Sat 08/12/2017 07:37:07 : [iNST-ACK    ] 02 62 23.D5.8D 0F 0D 00 06                 (00)
Sat 08/12/2017 07:37:07 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 0D 00           (00)
Sat 08/12/2017 07:37:07 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:37:07 : [23 D5 8D 0  ] Calibrating engine version
and this is the log from the "restore device command":
Sat 08/12/2017 07:38:18 : [  23 D5 8D 1] Preparing Device 'Ent Rm.LS.Main' for Restore
Sat 08/12/2017 07:38:18 : [  23 D5 8D 1] Device 'Ent Rm.LS.Main' ready for Full Restore
Sat 08/12/2017 07:38:18 : [All         ] Writing 19 bytes to devices
Sat 08/12/2017 07:38:18 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 0D 00
Sat 08/12/2017 07:38:18 : [iNST-ACK    ] 02 62 23.D5.8D 0F 0D 00 06                 (00)
Sat 08/12/2017 07:38:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 0D 00           (00)
Sat 08/12/2017 07:38:19 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:19 : [23 D5 8D 0  ] Calibrating engine version
Sat 08/12/2017 07:38:19 : [23 D5 8D 1  ] Link    0 : 0FF8 [A200306A65FF1F01] Writing [A200306A65FF1F01]
Sat 08/12/2017 07:38:19 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:19 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:19 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F8
Sat 08/12/2017 07:38:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F8 06          PEEK   (F8)
Sat 08/12/2017 07:38:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:19 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F8    PEEK   (F8)
Sat 08/12/2017 07:38:20 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:20 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 A2
Sat 08/12/2017 07:38:20 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 A2 06          POKE   (A2)
Sat 08/12/2017 07:38:22 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 A2    POKE   (A2)
Sat 08/12/2017 07:38:22 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:22 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F9
Sat 08/12/2017 07:38:22 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F9 06          PEEK   (F9)
Sat 08/12/2017 07:38:23 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 2B F9    PEEK   (F9)
Sat 08/12/2017 07:38:23 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:23 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:23 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 29 00    POKE   (00)
Sat 08/12/2017 07:38:24 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:24 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FA
Sat 08/12/2017 07:38:24 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FA 06          PEEK   (FA)
Sat 08/12/2017 07:38:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FA    PEEK   (FA)
Sat 08/12/2017 07:38:25 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 30
Sat 08/12/2017 07:38:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 30 06          POKE   (30)
Sat 08/12/2017 07:38:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 30    POKE   (30)
Sat 08/12/2017 07:38:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FB
Sat 08/12/2017 07:38:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FB 06          PEEK   (FB)
Sat 08/12/2017 07:38:26 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FB    PEEK   (FB)
Sat 08/12/2017 07:38:26 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:26 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 6A
Sat 08/12/2017 07:38:26 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 6A 06          POKE   (6A)
Sat 08/12/2017 07:38:26 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 6A    POKE   (6A)
Sat 08/12/2017 07:38:26 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:26 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FC
Sat 08/12/2017 07:38:26 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FC 06          PEEK   (FC)
Sat 08/12/2017 07:38:27 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 6A    POKE   (6A)
Sat 08/12/2017 07:38:27 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:27 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 2B FC    PEEK   (FC)
Sat 08/12/2017 07:38:27 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:27 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 65
Sat 08/12/2017 07:38:27 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 65 06          POKE   (65)
Sat 08/12/2017 07:38:27 : CLI-HAMW: Connecting to api.aerisapi.com
Sat 08/12/2017 07:38:27 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 65    POKE   (65)
Sat 08/12/2017 07:38:27 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:27 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FD
Sat 08/12/2017 07:38:27 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FD 06          PEEK   (FD)
Sat 08/12/2017 07:38:27 : CLI-HAMW: Successfully Processed HAMW Response
Sat 08/12/2017 07:38:28 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FD    PEEK   (FD)
Sat 08/12/2017 07:38:28 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:28 : CLI-HAMW: Successfully Processed HAMW Response
Sat 08/12/2017 07:38:28 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 FF
Sat 08/12/2017 07:38:28 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 FF 06          POKE   (FF)
Sat 08/12/2017 07:38:28 : CLI-HAMW: Connecting to api.aerisapi.com
Sat 08/12/2017 07:38:28 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 FF    POKE   (FF)
Sat 08/12/2017 07:38:28 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FE
Sat 08/12/2017 07:38:28 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FE 06          PEEK   (FE)
Sat 08/12/2017 07:38:29 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FE    PEEK   (FE)
Sat 08/12/2017 07:38:29 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:29 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 1F
Sat 08/12/2017 07:38:29 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 1F 06          POKE   (1F)
Sat 08/12/2017 07:38:31 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 1F    POKE   (1F)
Sat 08/12/2017 07:38:31 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:31 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FF
Sat 08/12/2017 07:38:31 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FF 06          PEEK   (FF)
Sat 08/12/2017 07:38:31 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FF    PEEK   (FF)
Sat 08/12/2017 07:38:31 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:31 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 01
Sat 08/12/2017 07:38:31 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 01 06          POKE   (01)
Sat 08/12/2017 07:38:32 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 01    POKE   (01)
Sat 08/12/2017 07:38:32 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:32 : [MNG-LNK-RSP ] 02 6F 40 E2 00 23 D5 8D 01 27 00 15
Sat 08/12/2017 07:38:32 : [PLM         ] Group   0 : Writing Controller Link matching [23 D5 8D 1  ] Link    0 : 0FF8 [A200306A65FF1F01]
Sat 08/12/2017 07:38:32 : [23 D5 8D 1  ] Link    1 : 0FF0 [E201306A65010001] Writing [E201306A65010001]
Sat 08/12/2017 07:38:32 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:32 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:33 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:33 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:33 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F0
Sat 08/12/2017 07:38:33 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F0 06          PEEK   (F0)
Sat 08/12/2017 07:38:33 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F0    PEEK   (F0)
Sat 08/12/2017 07:38:33 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 E2
Sat 08/12/2017 07:38:33 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 E2 06          POKE   (E2)
Sat 08/12/2017 07:38:34 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B F0    PEEK   (F0)
Sat 08/12/2017 07:38:34 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:34 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 E2    POKE   (E2)
Sat 08/12/2017 07:38:34 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:34 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F1
Sat 08/12/2017 07:38:34 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F1 06          PEEK   (F1)
Sat 08/12/2017 07:38:34 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F1    PEEK   (F1)
Sat 08/12/2017 07:38:34 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 01
Sat 08/12/2017 07:38:34 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 01 06          POKE   (01)
Sat 08/12/2017 07:38:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 01    POKE   (01)
Sat 08/12/2017 07:38:35 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F2
Sat 08/12/2017 07:38:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F2 06          PEEK   (F2)
Sat 08/12/2017 07:38:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F2    PEEK   (F2)
Sat 08/12/2017 07:38:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 30
Sat 08/12/2017 07:38:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 30 06          POKE   (30)
Sat 08/12/2017 07:38:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 30    POKE   (30)
Sat 08/12/2017 07:38:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:36 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F3
Sat 08/12/2017 07:38:36 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F3 06          PEEK   (F3)
Sat 08/12/2017 07:38:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 30    POKE   (30)
Sat 08/12/2017 07:38:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 2B F3    PEEK   (F3)
Sat 08/12/2017 07:38:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 6A
Sat 08/12/2017 07:38:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 6A 06          POKE   (6A)
Sat 08/12/2017 07:38:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B F3    PEEK   (F3)
Sat 08/12/2017 07:38:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 6A    POKE   (6A)
Sat 08/12/2017 07:38:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F4
Sat 08/12/2017 07:38:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F4 06          PEEK   (F4)
Sat 08/12/2017 07:38:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F4    PEEK   (F4)
Sat 08/12/2017 07:38:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 65
Sat 08/12/2017 07:38:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 65 06          POKE   (65)
Sat 08/12/2017 07:38:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 65    POKE   (65)
Sat 08/12/2017 07:38:38 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:38 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F5
Sat 08/12/2017 07:38:38 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F5 06          PEEK   (F5)
Sat 08/12/2017 07:38:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F5    PEEK   (F5)
Sat 08/12/2017 07:38:38 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 01
Sat 08/12/2017 07:38:38 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 01 06          POKE   (01)
Sat 08/12/2017 07:38:39 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 01    POKE   (01)
Sat 08/12/2017 07:38:39 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:39 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F6
Sat 08/12/2017 07:38:39 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F6 06          PEEK   (F6)
Sat 08/12/2017 07:38:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F6    PEEK   (F6)
Sat 08/12/2017 07:38:40 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:40 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:40 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:40 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F7
Sat 08/12/2017 07:38:40 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F7 06          PEEK   (F7)
Sat 08/12/2017 07:38:41 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F7    PEEK   (F7)
Sat 08/12/2017 07:38:41 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:41 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 01
Sat 08/12/2017 07:38:41 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 01 06          POKE   (01)
Sat 08/12/2017 07:38:43 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 01    POKE   (01)
Sat 08/12/2017 07:38:43 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:43 : [MNG-LNK-RSP ] 02 6F 41 A2 01 23 D5 8D 01 27 00 15
Sat 08/12/2017 07:38:43 : [PLM         ] Group   1 : Writing Responder Link matching [23 D5 8D 1  ] Link    1 : 0FF0 [E201306A65010001]
Sat 08/12/2017 07:38:43 : [23 D5 8D 1  ] Link    2 : 0FE8 [0000000000000000] Writing [00..............]
Sat 08/12/2017 07:38:43 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:44 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:44 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:44 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:44 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E8
Sat 08/12/2017 07:38:44 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E8 06          PEEK   (E8)
Sat 08/12/2017 07:38:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E8    PEEK   (E8)
Sat 08/12/2017 07:38:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B E8    PEEK   (E8)
Sat 08/12/2017 07:38:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 29 00    POKE   (00)
Sat 08/12/2017 07:38:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:38:46 : [23 D5 8D 1  ] Link    3 : 0FE0 : Writing High Water Byte
Sat 08/12/2017 07:38:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E0
Sat 08/12/2017 07:38:47 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E0 06          PEEK   (E0)
Sat 08/12/2017 07:38:47 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E0    PEEK   (E0)
Sat 08/12/2017 07:38:47 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:47 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:47 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:49 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:49 : [23 D5 8D 1  ] Link    4 : 0FD8 : Writing High Water Byte
Sat 08/12/2017 07:38:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B D8
Sat 08/12/2017 07:38:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B D8 06          PEEK   (D8)
Sat 08/12/2017 07:38:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B D8    PEEK   (D8)
Sat 08/12/2017 07:38:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:50 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:50 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B D8    PEEK   (D8)
Sat 08/12/2017 07:38:50 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:38:51 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:51 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:51 : [23 D5 8D 1  ] Link    5 : 0FD0 : Writing High Water Byte
Sat 08/12/2017 07:38:51 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:51 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:51 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:51 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B D0
Sat 08/12/2017 07:38:51 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B D0 06          PEEK   (D0)
Sat 08/12/2017 07:38:51 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B D0    PEEK   (D0)
Sat 08/12/2017 07:38:52 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:52 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:52 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:52 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:52 : [23 D5 8D 1  ] Link    6 : 0FC8 : Writing High Water Byte
Sat 08/12/2017 07:38:52 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:52 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:53 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:53 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:53 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B C8
Sat 08/12/2017 07:38:53 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B C8 06          PEEK   (C8)
Sat 08/12/2017 07:38:53 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B C8    PEEK   (C8)
Sat 08/12/2017 07:38:53 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:53 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:53 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:54 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:54 : [23 D5 8D 1  ] Link    7 : 0FC0 : Writing High Water Byte
Sat 08/12/2017 07:38:54 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:54 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:54 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:54 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B C0
Sat 08/12/2017 07:38:54 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B C0 06          PEEK   (C0)
Sat 08/12/2017 07:38:55 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 2B C0    PEEK   (C0)
Sat 08/12/2017 07:38:55 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:38:55 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:55 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:56 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:56 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:56 : [23 D5 8D 1  ] Link    8 : 0FB8 : Writing High Water Byte
Sat 08/12/2017 07:38:56 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:56 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:38:57 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:38:57 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:38:57 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B B8
Sat 08/12/2017 07:38:57 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B B8 06          PEEK   (B8)
Sat 08/12/2017 07:38:58 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B B8    PEEK   (B8)
Sat 08/12/2017 07:38:58 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:58 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:38:58 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:38:59 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:38:59 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:38:59 : [23 D5 8D 1  ] Link    9 : 0FB0 : Writing High Water Byte
Sat 08/12/2017 07:38:59 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:38:59 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:00 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:00 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:00 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B B0
Sat 08/12/2017 07:39:00 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B B0 06          PEEK   (B0)
Sat 08/12/2017 07:39:01 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B B0    PEEK   (B0)
Sat 08/12/2017 07:39:01 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:01 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:01 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:02 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 29 00    POKE   (00)
Sat 08/12/2017 07:39:02 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:02 : [23 D5 8D 1  ] Link   10 : 0FA8 : Writing High Water Byte
Sat 08/12/2017 07:39:02 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:02 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:02 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:02 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:02 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B A8
Sat 08/12/2017 07:39:02 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B A8 06          PEEK   (A8)
Sat 08/12/2017 07:39:03 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B A8    PEEK   (A8)
Sat 08/12/2017 07:39:03 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:03 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:03 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:04 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:04 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:04 : [23 D5 8D 1  ] Link   11 : 0FA0 : Writing High Water Byte
Sat 08/12/2017 07:39:04 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:04 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:05 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:05 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:05 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B A0
Sat 08/12/2017 07:39:05 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B A0 06          PEEK   (A0)
Sat 08/12/2017 07:39:05 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:05 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:05 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B A0    PEEK   (A0)
Sat 08/12/2017 07:39:05 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:05 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:05 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B A0    PEEK   (A0)
Sat 08/12/2017 07:39:06 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:06 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:06 : [23 D5 8D 1  ] Link   12 : 0F98 : Writing High Water Byte
Sat 08/12/2017 07:39:06 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:06 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:07 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:07 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:07 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 98
Sat 08/12/2017 07:39:07 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 98 06          PEEK   (98)
Sat 08/12/2017 07:39:07 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 2B 98    PEEK   (98)
Sat 08/12/2017 07:39:07 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:07 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:07 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:07 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 98    PEEK   (98)
Sat 08/12/2017 07:39:07 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:08 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:08 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:08 : [23 D5 8D 1  ] Link   13 : 0F90 : Writing High Water Byte
Sat 08/12/2017 07:39:08 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:08 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:08 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 00    POKE   (00)
Sat 08/12/2017 07:39:08 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:08 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:08 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 90
Sat 08/12/2017 07:39:08 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 90 06          PEEK   (90)
Sat 08/12/2017 07:39:09 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:09 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:09 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 2B 90    PEEK   (90)
Sat 08/12/2017 07:39:09 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:39:09 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:09 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:10 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:10 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:10 : [23 D5 8D 1  ] Link   14 : 0F88 : Writing High Water Byte
Sat 08/12/2017 07:39:10 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:10 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:11 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:11 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:11 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 88
Sat 08/12/2017 07:39:11 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 88 06          PEEK   (88)
Sat 08/12/2017 07:39:12 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 88    PEEK   (88)
Sat 08/12/2017 07:39:12 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:12 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:12 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:12 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 88    PEEK   (88)
Sat 08/12/2017 07:39:12 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:12 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:12 : [23 D5 8D 1  ] Link   15 : 0F80 : Writing High Water Byte
Sat 08/12/2017 07:39:12 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:12 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:13 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:13 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:13 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 80
Sat 08/12/2017 07:39:13 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 80 06          PEEK   (80)
Sat 08/12/2017 07:39:13 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 80    PEEK   (80)
Sat 08/12/2017 07:39:13 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:13 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:14 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:14 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:14 : [23 D5 8D 1  ] Link   16 : 0F78 : Writing High Water Byte
Sat 08/12/2017 07:39:14 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:14 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:15 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:15 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:15 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 78
Sat 08/12/2017 07:39:15 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 78 06          PEEK   (78)
Sat 08/12/2017 07:39:15 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:15 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:15 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 78    PEEK   (78)
Sat 08/12/2017 07:39:15 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:15 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:17 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:17 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:17 : [23 D5 8D 1  ] Link   17 : 0F70 : Writing High Water Byte
Sat 08/12/2017 07:39:17 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:17 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:18 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:18 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:18 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 70
Sat 08/12/2017 07:39:18 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 70 06          PEEK   (70)
Sat 08/12/2017 07:39:18 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:18 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:18 : [iNST-DUP    ] Previous message ignored.
Sat 08/12/2017 07:39:18 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 70    PEEK   (70)
Sat 08/12/2017 07:39:18 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:18 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:19 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:19 : [23 D5 8D 1  ] Link   18 : 0F68 : Writing High Water Byte
Sat 08/12/2017 07:39:19 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:19 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 68
Sat 08/12/2017 07:39:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 68 06          PEEK   (68)
Sat 08/12/2017 07:39:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 68    PEEK   (68)
Sat 08/12/2017 07:39:20 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:20 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:20 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:20 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:20 : [23 D5 8D 1  ] Link   19 : 0F60 : Writing High Water Byte
Sat 08/12/2017 07:39:20 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:21 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:23 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:23 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:23 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 60
Sat 08/12/2017 07:39:23 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 60 06          PEEK   (60)
Sat 08/12/2017 07:39:23 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 60    PEEK   (60)
Sat 08/12/2017 07:39:23 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:23 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:23 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 60    PEEK   (60)
Sat 08/12/2017 07:39:23 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:24 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:24 : [23 D5 8D 1  ] Link   20 : 0F58 : Writing High Water Byte
Sat 08/12/2017 07:39:24 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:24 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 00    POKE   (00)
Sat 08/12/2017 07:39:24 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:24 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:24 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 58
Sat 08/12/2017 07:39:24 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 58 06          PEEK   (58)
Sat 08/12/2017 07:39:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 58    PEEK   (58)
Sat 08/12/2017 07:39:25 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 58    PEEK   (58)
Sat 08/12/2017 07:39:25 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 29 00    POKE   (00)
Sat 08/12/2017 07:39:25 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:25 : [23 D5 8D 1  ] Link   21 : 0F50 : Writing High Water Byte
Sat 08/12/2017 07:39:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:34 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:34 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:35 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 50
Sat 08/12/2017 07:39:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 50 06          PEEK   (50)
Sat 08/12/2017 07:39:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 50    PEEK   (50)
Sat 08/12/2017 07:39:35 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 29 00    POKE   (00)
Sat 08/12/2017 07:39:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:39:36 : [23 D5 8D 1  ] Link   22 : 0F48 : Writing High Water Byte
Sat 08/12/2017 07:39:36 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:36 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:36 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 48
Sat 08/12/2017 07:39:36 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 48 06          PEEK   (48)
Sat 08/12/2017 07:39:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 48    PEEK   (48)
Sat 08/12/2017 07:39:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:36 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:36 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 48    PEEK   (48)
Sat 08/12/2017 07:39:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:37 : [23 D5 8D 1  ] Link   23 : 0F40 : Writing High Water Byte
Sat 08/12/2017 07:39:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:38 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:38 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 40
Sat 08/12/2017 07:39:38 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 40 06          PEEK   (40)
Sat 08/12/2017 07:39:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:38 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 40    PEEK   (40)
Sat 08/12/2017 07:39:40 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:40 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:40 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 40    PEEK   (40)
Sat 08/12/2017 07:39:40 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:41 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 29 00    POKE   (00)
Sat 08/12/2017 07:39:41 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:41 : [23 D5 8D 1  ] Link   24 : 0F38 : Writing High Water Byte
Sat 08/12/2017 07:39:41 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:41 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:43 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:43 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:39:43 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 38
Sat 08/12/2017 07:39:43 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 38 06          PEEK   (38)
Sat 08/12/2017 07:39:43 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 38    PEEK   (38)
Sat 08/12/2017 07:39:43 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:43 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:43 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:44 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:44 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:44 : [23 D5 8D 1  ] Link   25 : 0F30 : Writing High Water Byte
Sat 08/12/2017 07:39:44 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:44 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:44 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:44 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 30
Sat 08/12/2017 07:39:44 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 30 06          PEEK   (30)
Sat 08/12/2017 07:39:45 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 2B 30    PEEK   (30)
Sat 08/12/2017 07:39:45 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:39:45 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:45 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:46 : [23 D5 8D 1  ] Link   26 : 0F28 : Writing High Water Byte
Sat 08/12/2017 07:39:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 28
Sat 08/12/2017 07:39:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 28 06          PEEK   (28)
Sat 08/12/2017 07:39:47 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 28    PEEK   (28)
Sat 08/12/2017 07:39:47 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:47 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:47 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:47 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:47 : [23 D5 8D 1  ] Link   27 : 0F20 : Writing High Water Byte
Sat 08/12/2017 07:39:47 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:47 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:48 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:48 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:48 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 20
Sat 08/12/2017 07:39:48 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 20 06          PEEK   (20)
Sat 08/12/2017 07:39:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 20    PEEK   (20)
Sat 08/12/2017 07:39:49 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 00    POKE   (00)
Sat 08/12/2017 07:39:49 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:49 : [23 D5 8D 1  ] Link   28 : 0F18 : Writing High Water Byte
Sat 08/12/2017 07:39:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:52 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:52 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:52 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 18
Sat 08/12/2017 07:39:52 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 18 06          PEEK   (18)
Sat 08/12/2017 07:39:53 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B 18    PEEK   (18)
Sat 08/12/2017 07:39:53 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:53 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:53 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:54 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:54 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:54 : [23 D5 8D 1  ] Link   29 : 0F10 : Writing High Water Byte
Sat 08/12/2017 07:39:54 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:54 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:54 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 29 00    POKE   (00)
Sat 08/12/2017 07:39:54 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:55 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:55 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:39:55 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 10
Sat 08/12/2017 07:39:55 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 10 06          PEEK   (10)
Sat 08/12/2017 07:39:56 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 10    PEEK   (10)
Sat 08/12/2017 07:39:56 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:56 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:56 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:39:57 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 00    POKE   (00)
Sat 08/12/2017 07:39:57 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:57 : [23 D5 8D 1  ] Link   30 : 0F08 : Writing High Water Byte
Sat 08/12/2017 07:39:57 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:39:57 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:39:59 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:39:59 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:39:59 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 08
Sat 08/12/2017 07:39:59 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 08 06          PEEK   (08)
Sat 08/12/2017 07:39:59 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 2B 08    PEEK   (08)
Sat 08/12/2017 07:39:59 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:39:59 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 00
Sat 08/12/2017 07:39:59 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 00 06          POKE   (00)
Sat 08/12/2017 07:40:00 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 29 00    POKE   (00)
Sat 08/12/2017 07:40:00 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:40:00 : [23 D5 8D 1  ] Link   31 : 0F00 : Writing High Water Byte
Sat 08/12/2017 07:40:00 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:40:00 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:40:01 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:40:01 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:40:01 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 00
Sat 08/12/2017 07:40:01 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 00 06          PEEK   (00)
Sat 08/12/2017 07:40:01 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:40:01 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:40:02 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 00    PEEK   (00)
Sat 08/12/2017 07:40:02 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:40:02 : [23 D5 8D 1  ] Memory : Write dbAddr=0x0032 [FF] cmd1=0x2E cmd2=0x00
Sat 08/12/2017 07:40:02 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 00
Sat 08/12/2017 07:40:02 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 00 06          SET-MSB(00)
Sat 08/12/2017 07:40:02 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 00    SET-MSB(00)
Sat 08/12/2017 07:40:02 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 32
Sat 08/12/2017 07:40:02 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 32 06          PEEK   (32)
Sat 08/12/2017 07:40:03 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 32    PEEK   (32)
Sat 08/12/2017 07:40:03 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:40:03 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 FF
Sat 08/12/2017 07:40:03 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 FF 06          POKE   (FF)
Sat 08/12/2017 07:40:03 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 FF    POKE   (FF)
Sat 08/12/2017 07:40:03 : [23 D5 8D 1  ] Memory : Write dbAddr=0x0021 [1E] cmd1=0x2E cmd2=0x00
Sat 08/12/2017 07:40:03 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 00
Sat 08/12/2017 07:40:03 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 00 06          SET-MSB(00)
Sat 08/12/2017 07:40:05 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 00    SET-MSB(00)
Sat 08/12/2017 07:40:05 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:40:05 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B 21
Sat 08/12/2017 07:40:05 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B 21 06          PEEK   (21)
Sat 08/12/2017 07:40:06 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B 21    PEEK   (21)
Sat 08/12/2017 07:40:06 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:40:06 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 29 1E
Sat 08/12/2017 07:40:06 : [iNST-ACK    ] 02 62 23.D5.8D 0F 29 1E 06          POKE   (1E)
Sat 08/12/2017 07:40:06 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 29 1E    POKE   (1E)
thanks
Peter
one more log file output. This is what I get if I read the device link table after having run the restore as shown in the first post.
I only asked it to show the first 5 entries to save space.
Sat 08/12/2017 07:54:10 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:10 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:10 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:10 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:10 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F8
Sat 08/12/2017 07:54:10 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F8 06          PEEK   (F8)
Sat 08/12/2017 07:54:11 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F8    PEEK   (F8)
Sat 08/12/2017 07:54:11 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:11 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:11 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:12 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:12 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:54:12 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F9
Sat 08/12/2017 07:54:12 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F9 06          PEEK   (F9)
Sat 08/12/2017 07:54:12 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F9    PEEK   (F9)
Sat 08/12/2017 07:54:12 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:12 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:13 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:13 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:13 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:13 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FA
Sat 08/12/2017 07:54:14 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FA 06          PEEK   (FA)
Sat 08/12/2017 07:54:14 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FA    PEEK   (FA)
Sat 08/12/2017 07:54:14 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:14 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:14 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:14 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:14 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FB
Sat 08/12/2017 07:54:14 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FB 06          PEEK   (FB)
Sat 08/12/2017 07:54:15 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FB    PEEK   (FB)
Sat 08/12/2017 07:54:15 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:15 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:15 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:16 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:16 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:54:16 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FC
Sat 08/12/2017 07:54:16 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FC 06          PEEK   (FC)
Sat 08/12/2017 07:54:16 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FC    PEEK   (FC)
Sat 08/12/2017 07:54:16 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:16 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:17 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:17 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:17 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:17 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FD
Sat 08/12/2017 07:54:17 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FD 06          PEEK   (FD)
Sat 08/12/2017 07:54:18 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B FD    PEEK   (FD)
Sat 08/12/2017 07:54:18 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:18 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:18 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:18 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:18 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:18 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FE
Sat 08/12/2017 07:54:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FE 06          PEEK   (FE)
Sat 08/12/2017 07:54:19 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FE    PEEK   (FE)
Sat 08/12/2017 07:54:19 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:19 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:19 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:20 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:20 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B FF
Sat 08/12/2017 07:54:20 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B FF 06          PEEK   (FF)
Sat 08/12/2017 07:54:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:20 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:20 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B FF    PEEK   (FF)
Sat 08/12/2017 07:54:20 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:20 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:21 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 27 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:21 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 08/12/2017 07:54:21 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F0
Sat 08/12/2017 07:54:21 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F0 06          PEEK   (F0)
Sat 08/12/2017 07:54:21 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F0    PEEK   (F0)
Sat 08/12/2017 07:54:21 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:21 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:22 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:22 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:22 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:22 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F1
Sat 08/12/2017 07:54:22 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F1 06          PEEK   (F1)
Sat 08/12/2017 07:54:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F1    PEEK   (F1)
Sat 08/12/2017 07:54:24 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:24 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:24 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:24 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F2
Sat 08/12/2017 07:54:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F2 06          PEEK   (F2)
Sat 08/12/2017 07:54:25 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F2    PEEK   (F2)
Sat 08/12/2017 07:54:25 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:25 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:25 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:26 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2B 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:26 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 08/12/2017 07:54:26 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F3
Sat 08/12/2017 07:54:26 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F3 06          PEEK   (F3)
Sat 08/12/2017 07:54:27 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F3    PEEK   (F3)
Sat 08/12/2017 07:54:27 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:27 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:27 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:27 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:27 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F4
Sat 08/12/2017 07:54:27 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F4 06          PEEK   (F4)
Sat 08/12/2017 07:54:28 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F4    PEEK   (F4)
Sat 08/12/2017 07:54:28 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:28 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:28 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:28 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:28 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F5
Sat 08/12/2017 07:54:28 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F5 06          PEEK   (F5)
Sat 08/12/2017 07:54:29 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F5    PEEK   (F5)
Sat 08/12/2017 07:54:29 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:29 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:29 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:29 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B F5    PEEK   (F5)
Sat 08/12/2017 07:54:29 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:29 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:29 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F6
Sat 08/12/2017 07:54:30 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F6 06          PEEK   (F6)
Sat 08/12/2017 07:54:30 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B F6    PEEK   (F6)
Sat 08/12/2017 07:54:30 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:30 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:30 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:31 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:31 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:31 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B F7
Sat 08/12/2017 07:54:31 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B F7 06          PEEK   (F7)
Sat 08/12/2017 07:54:32 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B F7    PEEK   (F7)
Sat 08/12/2017 07:54:32 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:32 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:32 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:32 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B F7    PEEK   (F7)
Sat 08/12/2017 07:54:32 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:33 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:33 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:33 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E8
Sat 08/12/2017 07:54:33 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E8 06          PEEK   (E8)
Sat 08/12/2017 07:54:33 : [iNST-SRX    ] 02 50 B8.45.8D 30.6A.65 26 53 83           (83)
Sat 08/12/2017 07:54:33 : [std-Direct Ack] B8.45.8D-->ISY/PLM Group=0, Max Hops=2, Hops Left=1
Sat 08/12/2017 07:54:33 : [iNST-DUP    ] Previous message ignored.
Sat 08/12/2017 07:54:33 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E8    PEEK   (E8)
Sat 08/12/2017 07:54:33 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:33 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:34 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:34 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:34 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E9
Sat 08/12/2017 07:54:34 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E9 06          PEEK   (E9)
Sat 08/12/2017 07:54:34 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E9    PEEK   (E9)
Sat 08/12/2017 07:54:34 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:34 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:35 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B EA
Sat 08/12/2017 07:54:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B EA 06          PEEK   (EA)
Sat 08/12/2017 07:54:35 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B EA    PEEK   (EA)
Sat 08/12/2017 07:54:35 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:35 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:36 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:36 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:36 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B EB
Sat 08/12/2017 07:54:36 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B EB 06          PEEK   (EB)
Sat 08/12/2017 07:54:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B EB    PEEK   (EB)
Sat 08/12/2017 07:54:37 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:37 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:37 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B EC
Sat 08/12/2017 07:54:37 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B EC 06          PEEK   (EC)
Sat 08/12/2017 07:54:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B EC    PEEK   (EC)
Sat 08/12/2017 07:54:38 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:38 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:38 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B EC    PEEK   (EC)
Sat 08/12/2017 07:54:38 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:38 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:38 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B ED
Sat 08/12/2017 07:54:38 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B ED 06          PEEK   (ED)
Sat 08/12/2017 07:54:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B ED    PEEK   (ED)
Sat 08/12/2017 07:54:40 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:40 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:40 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:40 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:40 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B EE
Sat 08/12/2017 07:54:40 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B EE 06          PEEK   (EE)
Sat 08/12/2017 07:54:41 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B EE    PEEK   (EE)
Sat 08/12/2017 07:54:41 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:41 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:41 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:42 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:42 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:42 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B EF
Sat 08/12/2017 07:54:42 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B EF 06          PEEK   (EF)
Sat 08/12/2017 07:54:43 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B EF    PEEK   (EF)
Sat 08/12/2017 07:54:43 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:43 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:43 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:45 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:45 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:45 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E0
Sat 08/12/2017 07:54:45 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E0 06          PEEK   (E0)
Sat 08/12/2017 07:54:45 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E0    PEEK   (E0)
Sat 08/12/2017 07:54:45 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:45 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:45 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B E0    PEEK   (E0)
Sat 08/12/2017 07:54:45 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E1
Sat 08/12/2017 07:54:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E1 06          PEEK   (E1)
Sat 08/12/2017 07:54:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E1    PEEK   (E1)
Sat 08/12/2017 07:54:46 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:46 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:46 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:46 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E2
Sat 08/12/2017 07:54:47 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E2 06          PEEK   (E2)
Sat 08/12/2017 07:54:48 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E2    PEEK   (E2)
Sat 08/12/2017 07:54:48 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:48 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:48 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:49 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E3
Sat 08/12/2017 07:54:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E3 06          PEEK   (E3)
Sat 08/12/2017 07:54:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E3    PEEK   (E3)
Sat 08/12/2017 07:54:49 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:49 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:49 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 23 2B E3    PEEK   (E3)
Sat 08/12/2017 07:54:49 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 08/12/2017 07:54:50 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:50 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:50 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E4
Sat 08/12/2017 07:54:50 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E4 06          PEEK   (E4)
Sat 08/12/2017 07:54:51 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E4    PEEK   (E4)
Sat 08/12/2017 07:54:51 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:51 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:51 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:51 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:51 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E5
Sat 08/12/2017 07:54:51 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E5 06          PEEK   (E5)
Sat 08/12/2017 07:54:52 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E5    PEEK   (E5)
Sat 08/12/2017 07:54:52 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:52 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:52 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:53 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:53 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:53 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E6
Sat 08/12/2017 07:54:53 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E6 06          PEEK   (E6)
Sat 08/12/2017 07:54:54 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E6    PEEK   (E6)
Sat 08/12/2017 07:54:54 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:54 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 28 0F
Sat 08/12/2017 07:54:54 : [iNST-ACK    ] 02 62 23.D5.8D 0F 28 0F 06          SET-MSB(0F)
Sat 08/12/2017 07:54:54 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 28 0F    SET-MSB(0F)
Sat 08/12/2017 07:54:54 : [iNST-TX-I1  ] 02 62 23 D5 8D 0F 2B E7
Sat 08/12/2017 07:54:54 : [iNST-ACK    ] 02 62 23.D5.8D 0F 2B E7 06          PEEK   (E7)
Sat 08/12/2017 07:54:55 : [iNST-SRX    ] 02 50 23.D5.8D 30.6A.65 2F 2B E7    PEEK   (E7)
Sat 08/12/2017 07:54:55 : [std-Direct Ack] 23.D5.8D-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Sat 08/12/2017 07:54:55 : [All         ] Writing 0 bytes to devices
Whenever I find a mismatch and restore doesn't help, I take the following steps:
1. Show Device Links Table
2. From the Device Links Table select [Compare]. This will bring up the ISY Links Table
3. From the ISY Links Table select [save] (note the name and location of the file)
4. From the Device Links Table select [Load]. Choose the file you just saved.
Nope, that updates the device itself to what the ISY considers correct. Is that not happening?
Hope. It loads the file into the Dialog Window but it doesnt send out any commands that can be seen in the log (Level 3). There also appears to be no Button to ask it to update the device with the content.
Each and every time I followed the procedure I outlined in post #3 and the have been several, the device in question updated so that there was no mismatch between what the device reported and what the ISY reported. I don't know why you are not achieving that result.
