New Device
Hi io_guy
I presently have NodeLink supporting my Venstar thermostat. Works perfectly. I was wondering if I could suggest and additional device to be supported. There's this WiFi system that monitors the level of your propane tank. 'http://www.tankutility.com/residential-propane-tank-monitor'It's cloud based and accessible through a phone App. It does have APIs for accessing the data from their servers.  It looks like you receive a token from a logon and then use that to receive a string of data from the selected tank. It would probably take me weeks or months to put together a script in Pi to accomplish this and it wouldn't rely be a node, just data that could be sent to variables in the ISY via Rest I'm guessing.
Thanks for any consideration.
Gary
Looks like the site is back up, API is pretty simple.  I'd need your login to get it working so that I can see actual values.
If you're willing I can work on it in about a week.
Thanks io_guy
I will go ahead and order the system and provide you with all the info. They do say it may take two weeks to ship however.
Will let you know when I get it installed.
Again Thanks
Gary
  • 1 month later...
Hi io_guy
I finally received the propane tank hardware and finished installing it.
I sent you a message with my login info.
Again Thanks
Gary
Hi
I tried to add the tank utility node but couldn't scroll down to see it. Tried max resolution but still couldn't get to the bottom of the list to see tank utility.
Can scrolling be added?
Gary
I'm guessing you mean in the ISY.
You don't do that with NodeLink. It'll add the nodes to the ISY itself once you setup your Tank Utility credentials.
Yes in the ISY I can't get to the bottom of the node list to add tank utility node.
This is what I get on the NodeLink log:
   2017-10-16 08:33:34 - Tank Utility Web Response Error - SendFailure [tutil1]
   2017-10-16 08:37:47 - Tank Utility Web Response Error - SendFailure [tutil1]
I did set up my login and password in a new tutil1 device but not sure if the sendfailure is to tank utility or to the ISY.
No tank node gets added to the ISY.
Also I downloaded the latest nodesetup.zip into the ISY and rebooted.
Attached is NodeLink device tap.
Gary
Edited by garybixler
The error is for connecting to Tank Utility. NodeLink will not add the node to the ISY until it successfully connects to Tank.
What OS are you running and if not Windows what mono version (mono version is in the NodeLink log at startup)?
Also, any chance you have a firewall blocking NodeLink? Venstar connects locally, Tank Utility is cloud.
I am running windows 7 prof. I have assumed that if NodeLink can get auto updates that the firewall wouldn't be an issue. But I will look into it.
Mono version: 3.2.8 (Debian 3.2.8+dfsg-4+rpi1)
Update: I tried to log into tankutility from the browser running on the pi NodeLink is running on and was successful.
So it's a Pi, not Windows 7. I need the mono version.
This is likely an SSL certificate issue with the Pi.
You are correct about port 443.
I tried telnet to google.com 80 and it worked but it won't connect using port 443
But the browser in the pi will connect and use https after logging into tankutilty.
Hi
I started from scratch and created the latest version of Pi from your down loads. The tank utility connects now and the Venstar works fine.
I do however get this error:
2017-10-18 13:56:22 - Tank Utility Poll Error - Conversion from string "68.90024" to type 'Integer' is not valid. [tutil1]
2017-10-18 13:57:26 - Tank Utility Poll Error - Conversion from string "68.90024" to type 'Integer' is not valid. [tutil1]
so nothing is filled out in the Tank Utility node.
Status ID 0013004c393330330c473730   Name MyHome   Address 1000 Plunxxxxxxxxxxxxx   Capacity 500   Level %   Temperature     Time     Time ISO
Gary
