Can not exclude z-wave devise
Sbj. Talking about z-wave garage sensor.
Sat 09/02/2017 16:15:28 : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 29 (0x1D) ----
Sat 09/02/2017 16:15:28 : [ZWAVE-NODE-SYNC] -- Finished -- ISY/Z-Wave Node Sync --
Sat 09/02/2017 16:19:25 : [uZW-CMD 2       ] Start Exclude
Sat 09/02/2017 16:19:25 : Listening for Z-Wave devices to remove from the network
Sat 09/02/2017 16:19:29 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:31 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:32 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:33 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:41 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:42 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:46 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:47 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:48 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:49 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:50 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:53 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:54 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:19:55 : [ZWAVE-DB        ] Unexpected NULL database for uid=29 0x1D
Sat 09/02/2017 16:20:00 : [uZW-CMD 8       ] Cancel Include/Exclude/Learn
Sat 09/02/2017 16:20:00 : Removing Z-Wave devices stopped
Any idea what to do?
What are the steps you are taking to exclude the device. Also which specific Z-Wave garage door controller, there are several? Or do you mean the sensor only and not the controller?
Ecolink. I have a quite big z-wave network and included and excluded many devices. But have got problems only with this one. I use standard ISY procedure. Reset of the device doesn't work. Change of the battery doesn't work.
Repeat: there is no standard ISY procedure. The procedure depends on the device!!! The device you mentioned does not have a reset.
"To reset the Ecolink Tilt Sensor. When you see the message "Please follow manufacturer's instructions to remove the Z-Wave device from My SmartThings," do the following: Remove the sensor's cover. Remove the battery for at least 5 seconds."
Same reset should work for ISY as well. Why not? But it doesn't work anyway. :)
"Standard procedure" I mean ISY option include/exclude z-wave device. It usually works ok.
Edited by Aries
What steps are you taking and in what order? stating that you're following directions is meaningless. Write exactly what you are doing and in which specific order, for example, "first I'm ..., second etc." Or simply number the steps.
