boojew Posted September 3, 2017 Posted September 3, 2017 So, I have an odd issue... I installed a 2477d Switchlinc in a double gang box w/ a humidity sensing fan switch. Now, whenever the switchlinc has its settings updated (switch I do twice daily to change the on level), the fan cycles on and off anywhere from 1-3 times. I really have no clue what is happening here. Turning on the switch manually or via insteon command doesnt appear to have any affect.
Teken Posted September 3, 2017 Posted September 3, 2017 Does the 2477D have direct control of the fan? Sent from my iPhone using Tapatalk
Brian H Posted September 3, 2017 Posted September 3, 2017 (edited) If the 2477D is not controlling to the humidity fan controller. It is possible the Insteon Power Line commands are triggering it. When you send the level changes to the 2477D. I have seen posts where the Insteon Power Line commands are effecting things like lights on manual dimmers that are not Insteon. Edited September 3, 2017 by Brian H 1
mwester Posted September 3, 2017 Posted September 3, 2017 More likely that the RF from the 2477 is leaking into the humidity sense circuitry on the humidity-controlled switch. Not much you can do about that, except remove the 2477 and replace it with a standard switch. Or replace the humidity-controlled switch. It's NOT a good idea to try to block the RF inside the junction box -- wrapping things with aluminum foil, for example, is a recipe for a short-circuit, or a fire, but even if you get lucky and don't short anything, it may very well end up causing overheating of the devices. Perhaps you can find an ancient power-line-only insteon switch to try?
boojew Posted September 4, 2017 Author Posted September 4, 2017 On 9/3/2017 at 5:19 PM, Teken said: Does the 2477D have direct control of the fan? Sent from my iPhone using Tapatalk Nope. On 9/3/2017 at 5:41 PM, Brian H said: If the 2477D is not controlling to the humidity fan controller. It is possible the Insteon Power Line commands are triggering it. When you send the level changes to the 2477D. I have seen posts where the Insteon Power Line commands are effecting things like lights on manual dimmers that are not Insteon. Yea, that is what my guess was - I just wasnt sure if this was crazy talk or not... but seems it isnt. On 9/3/2017 at 7:01 PM, mwester said: More likely that the RF from the 2477 is leaking into the humidity sense circuitry on the humidity-controlled switch. Not much you can do about that, except remove the 2477 and replace it with a standard switch. Or replace the humidity-controlled switch. It's NOT a good idea to try to block the RF inside the junction box -- wrapping things with aluminum foil, for example, is a recipe for a short-circuit, or a fire, but even if you get lucky and don't short anything, it may very well end up causing overheating of the devices. Perhaps you can find an ancient power-line-only insteon switch to try? Thanks, I was assuming powerline was the issue, but this could be something to try... I may actually have a 2476D somewhere. I believe I read that this is powerline only, is that correct? I also have a 2-wire, but all of sudden ISY cant communicate with it.. I think it died
paulbates Posted September 4, 2017 Posted September 4, 2017 On 9/4/2017 at 1:41 PM, boojew said: I may actually have a 2476D somewhere. I believe I read that this is powerline only, is that correct? I also have a 2-wire, but all of sudden ISY cant communicate with it.. I think it died Yes, single band and worth a try. Only use the the 2 wire when there is no neutral and you have no other option Paul
larryllix Posted September 4, 2017 Posted September 4, 2017 (edited) In V5.0.10 you can turn many Insteon devices RF and/or Powerine fuctions on and off from the Admin Console. Edited September 4, 2017 by larryllix
Teken Posted September 4, 2017 Posted September 4, 2017 On 9/4/2017 at 1:51 PM, larryllix said: In V5.0.10 you can turn many Insteon devices RF and/or Powerine fuctions on and off from the Admin Console. There are only a hand full of Insteon devices which the firmware supports the ability to select RF / Powerline to be disabled. Of the top of my head they are the dual outlet, plugin on-off relay module. None of the single band switches / KPL's have ever offered such an option. Even newer dual band switches and KPL's don't offer such an option unless something has changed recently.
stusviews Posted September 4, 2017 Posted September 4, 2017 Those same options are available with v4.6.1, maybe even earlier.
Brian H Posted September 4, 2017 Posted September 4, 2017 The two wire is RF only. Since it gets its power through the load. It is strictly for incandescent or 120 volt power saving halogen incandescent replacements.
boojew Posted September 5, 2017 Author Posted September 5, 2017 On 9/4/2017 at 1:49 PM, paulbates said: Yes, single band and worth a try. Only use the the 2 wire when there is no neutral and you have no other option Paul Just installed a 2476D and it's definitely happening less frequently, but it is happening. I'll see how annoying this gets and if need be, replace the humidity switch. Thanks so much for your help, guys!
