Google Home & ZWave Locks
LDWelton
So I set up my Weiser ZWave lock in the portal to use with my Google Home.  I un-linked my account and re-linked several times in Google Home app but the lock does not appear in the list of devices.  I checked and ISY can communicate with lock and I can control it through MobiLinc App (Through portal).
Is this a known issue?  Can you think of anything I can check? :unsure:
Thanks for any Help you can provide.
Lloyd
What is synchronize???
ISY/Home does support thermostats or locks yet.
https://r.tapatalk.com/shareLink?url=http%3A%2F%2Fforum%2Euniversal-devices%2Ecom%2Findex%2Ephp%3F%2Ftopic%2F21744-It%27s-Alive%21%23entry212017&share_tid=21744&share_fid=23986&share_type=t&share_pid=212017
Hello all,
Verbatim from Benoit:
Hi Michel,
No, Google Home does not yet support thermostats, nor locks.
All that they support is regular lighting & switches. ISY Portal extends this to scene......
Sent from my Pixel C using Tapatalk
So I created A work around to accomplish this.
In Admin console, I made two scenes (lock & Unlock) each with a keypad button set as responder.  I also made two programs (again lock & unlock) if Button A (or Button B ) is on then lock (or unlock) the door and turn off the scene with Button A (or Button B ).  Then went into the portal and used IFTTT option for the two scenes(again lock & unlock) to turn on.  Finally went into IFTTT and made applets using Google Assistant as IF and Webhooks as That.
Bing, Bang, Boom  It Works!!!!!  :D
I can now control my locks using my voice.
Clear as mud right :wink:
Edited by LDWelton
So I have found a more elegant way to accomplish voice control of my locks.  It no longer requires keypadlinc buttons and scenes.  I wrote a program that is not enabled:
SDControl - [ID 0013][Parent 0001][Not Enabled]
        Set 'SideDoor' Unlock
        Set 'SideDoor' Lock
then in the portal under IFTTT Connectivity I chose program, for unlock I chose "Run Then" and of course for lock "Run Else".  Then as normal made applets in IFTTT with Google Assistant as IF and Webhooks in THAT.
Much Simpler!
      37.6k
      376.2k
