ISY not found
How to trouble shoot when the message is:   ISY Finder: Not Found
Thank you!
My only experience is to delete it and redownload.
Did you update your firmware recently?
Are you getting the "ISY Not Found" message when trying to connect the ISY Portal to the ISY?  If so has anyone issued an SPD command via TELNET to your ISY?   If the Portal is using My.ISY.IO to connect then go back to TELNET and issue a DPD command to delete the entry stored there. Then MY.ISY.IO shouid find the ISY ok.  I am not an expert on this but I had this experience myself and deleting my entire 300 entry Portal setup did not resolve the issue. The DPD is the only command that resolved this for me.
