Adding zwave device recognized but not showing up in tree
I have the same issue as this post but did not find any solution.
http://forum.universal-devices.com/topic/14045-cant-add-z-wave-devices/
Before I explain the issue I would like to say that I have a bunch of Bali Z-Wave Motorized Shades already working and I also tried removing and adding them again, and they work just fine.
But this last one that I am trying to add I get the following issue:
In the admin console, I go to Z-wave then Add.  I put the shade into link mode and it seems to link just fine:
Sun 09/17/2017 14:17:21 : Listening for Z-Wave devices to add to the network
Sun 09/17/2017 14:17:39 : [ZWAVE-RX        ] [0107004A19020000]...
Sun 09/17/2017 14:17:39 : [ZWAVE-TX        ] ACK
Sun 09/17/2017 14:17:39 : Z-Wave device detected, retrieving info 2
Sun 09/17/2017 14:17:39 : [ZWAVE-RX        ] [0115004A1903130E]...
Sun 09/17/2017 14:17:39 : Z-Wave device detected, retrieving info 3
Sun 09/17/2017 14:17:51 : [ZWAVE-RX        ] [0107004A19051300]...
Sun 09/17/2017 14:17:51 : [ZWAVE-TX        ] ACK
Sun 09/17/2017 14:17:51 : Z-Wave device detected, retrieving info 5
Sun 09/17/2017 14:17:51 : [ZWAVE-TX        ] [0105004A851A2F]
Sun 09/17/2017 14:17:51 : [ZWAVE-RX        ] ACK
Sun 09/17/2017 14:17:51 : [ZWAVE-RX        ] [0107004A1A061300]...
Sun 09/17/2017 14:17:51 : Adding Z-Wave devices stopped
Sun 09/17/2017 14:17:51 : [ZWAVE-TX        ] [01030020DC]
Sun 09/17/2017 14:17:51 : [ZWAVE-RX        ] [01080120EC772964]...
Sun 09/17/2017 14:17:52 : [ZWAVE-TX        ] [01030002FE]
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] ACK
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] [0125010205001DBD]...
Sun 09/17/2017 14:17:52 : [ZWAVE-TX        ] ACK
Sun 09/17/2017 14:17:52 : [ZWAVE-TX        ] [01030005F9]
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] [0104010508F7]
Sun 09/17/2017 14:17:52 : Device 24 of type 4.17.7 included into Z-Wave network
Sun 09/17/2017 14:17:52 : [ZWAVE-TX        ] [0109001313027204]...
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] [0104011301E8]
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] [010500131B00F2]
Sun 09/17/2017 14:17:52 : [ZWAVE-RX        ] [010E000400130872]...
Sun 09/17/2017 14:17:52 : Adding ISY node(s) for new Z-Wave device 24 type 4.17.7
Sun 09/17/2017 14:17:52 : [ZWAVE-ADD-NODE  ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07
I know that the linking was successful because the shade jogs which is the shade's tell for it.
I can also exclude the device successfully, and try to add again, but same problem.  The devices never show up in the tree, though the ISY seems to remember them.
When I Sync New & Deleted Nodes I get this output for it.
Sun 09/17/2017 14:52:44 : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 24 (0x18) ----
Sun 09/17/2017 14:52:44 : [ZWAVE-TX        ] [010400601883]
Sun 09/17/2017 14:52:44 : [ZWAVE-RX        ] ACK
Sun 09/17/2017 14:52:44 : [ZWAVE-RX        ] [01040160019B]
Sun 09/17/2017 14:52:44 : [ZWAVE-TX        ] ACK
Sun 09/17/2017 14:52:45 : [ZWAVE-RX        ] [0114004984180E04]...
Sun 09/17/2017 14:52:45 : [ZWAVE-TX        ] ACK
Sun 09/17/2017 14:52:45 : [ZWAVE-TX        ] [0109001318027204]...
Sun 09/17/2017 14:52:45 : [ZWAVE-RX        ] ACK
Sun 09/17/2017 14:52:45 : [ZWAVE-RX        ] [0104011301E8]
Sun 09/17/2017 14:52:45 : [ZWAVE-RX        ] [01050013900079]
Sun 09/17/2017 14:52:45 : [ZWAVE-RX        ] [010E000400180872]...
Sun 09/17/2017 14:52:45 : [ZWAVE-DB        ] Warning: Database already exists for uid=24 0x18
Sun 09/17/2017 14:52:45 : Adding ISY node(s) for new Z-Wave device 24 type 4.17.7
Sun 09/17/2017 14:52:45 : [ZWAVE-ADD-NODE  ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07
Sun 09/17/2017 14:52:45 : [ZWAVE-NODE-SYNC] Processing Z-Wave Node 24 (0x18) Failed, node ignored
How can I fix this ?
Any  help would be greatly appreciated
Have you tried heal? synchronize?
Thanks for the reply. yes I tried heal and synchronize. On synchronize I get the message as pasted above
Edited by stephan
Do you need the ISY firmware or the zwave dongle ? I'll check as soon as I am back home
Edited by stephan
ISY: v4.6.2
Z-Wave Version 4.55
Bootloader Version 1.03
Also, just want make sure my comment from above was noticed. I have the exact same model already working and I can remove and add it. But this last one that was part of my order doesn't seem to work to connect. Shd I send you some trace information ? Or do I need a reset ? I was trying to avoid a reset and re-enroll of all my devices
-Stephan
Is the ISY firmware and UI both 4.6.2? What's the result if you exclude the device (more than once)?
Hi, yes it is 4.6.2 for both the UI and the ISY firmware.
I just did the add and then two removes and I get this
ADD
Mon 09/18/2017 22:01:00 : [ZWAVE-TX-NR     ] [0105004AC16110]
Mon 09/18/2017 22:01:00 : [UZW-CMD 1       ] Start Include
Mon 09/18/2017 22:01:00 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:01:00 : [ZWAVE-RX        ] [0107004A61010000]...
Mon 09/18/2017 22:01:00 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:01:00 : Listening for Z-Wave devices to add to the network
Mon 09/18/2017 22:01:10 : [ZWAVE-RX        ] [0107004A61020000]...
Mon 09/18/2017 22:01:10 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:01:10 : Z-Wave device detected, retrieving info 2
Mon 09/18/2017 22:01:10 : [ZWAVE-RX        ] [0115004A6103190E]...
Mon 09/18/2017 22:01:10 : Z-Wave device detected, retrieving info 3
Mon 09/18/2017 22:01:22 : [ZWAVE-RX        ] [0107004A61051900]...
Mon 09/18/2017 22:01:22 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:01:22 : Z-Wave device detected, retrieving info 5
Mon 09/18/2017 22:01:22 : [ZWAVE-TX        ] [0105004A856257]
Mon 09/18/2017 22:01:23 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:01:23 : [ZWAVE-RX        ] [0107004A62061900]...
Mon 09/18/2017 22:01:23 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:01:23 : Adding Z-Wave devices stopped
Mon 09/18/2017 22:01:23 : [ZWAVE-TX        ] [01030020DC]
Mon 09/18/2017 22:01:23 : [ZWAVE-RX        ] [01080120EC772964]...
Mon 09/18/2017 22:01:24 : [ZWAVE-TX        ] [01030002FE]
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] [0125010205001DBD]...
Mon 09/18/2017 22:01:24 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:01:24 : [ZWAVE-TX        ] [01030005F9]
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] [0104010508F7]
Mon 09/18/2017 22:01:24 : Device 25 of type 4.17.7 included into Z-Wave network
Mon 09/18/2017 22:01:24 : [ZWAVE-TX        ] [0109001319027204]...
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] [0104011301E8]
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] [0105001363008A]
Mon 09/18/2017 22:01:24 : [ZWAVE-RX        ] [010E000400190872]...
Mon 09/18/2017 22:01:24 : Adding ISY node(s) for new Z-Wave device 25 type 4.17.7
Mon 09/18/2017 22:01:24 : [ZWAVE-ADD-NODE  ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07
SYNC
Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] ---- Start Processing Z-Wave Node 25 (0x19) ----
Mon 09/18/2017 22:04:16 : [ZWAVE-TX        ] [010400601982]
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] [01040160019B]
Mon 09/18/2017 22:04:16 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] [0114004984190E04]...
Mon 09/18/2017 22:04:16 : [ZWAVE-TX        ] [0109001319027204]...
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] [0104011301E8]
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] [0105001364008D]
Mon 09/18/2017 22:04:16 : [ZWAVE-RX        ] [010E000400190872]...
Mon 09/18/2017 22:04:16 : [ZWAVE-DB        ] Warning: Database already exists for uid=25 0x19
Mon 09/18/2017 22:04:16 : Adding ISY node(s) for new Z-Wave device 25 type 4.17.7
Mon 09/18/2017 22:04:16 : [ZWAVE-ADD-NODE  ] Add device: mfg 026E.4353.5A31, basic=0x04 gen=0x11 spec=0x07
Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] Processing Z-Wave Node 25 (0x19) Failed, node ignored
Mon 09/18/2017 22:04:16 : [ZWAVE-NODE-SYNC] -- Finished -- ISY/Z-Wave Node Sync --
REMOVE 1
Mon 09/18/2017 22:05:55 : [ZWAVE-TX-NR     ] [0105004B0165D5]
Mon 09/18/2017 22:05:55 : [UZW-CMD 2       ] Start Exclude
Mon 09/18/2017 22:05:55 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:05:55 : [ZWAVE-RX        ] [0107004B65010000]...
Mon 09/18/2017 22:05:55 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:05:55 : Listening for Z-Wave devices to remove from the network
Mon 09/18/2017 22:06:05 : [ZWAVE-RX        ] [0107004B65020000]...
Mon 09/18/2017 22:06:05 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] [0115004B6503190E]...
Mon 09/18/2017 22:06:06 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] [0115004B6506190E]...
Mon 09/18/2017 22:06:06 : Removing Z-Wave devices stopped
Mon 09/18/2017 22:06:06 : [ZWAVE-TX        ] [01030020DC]
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] [01080120EC772964]...
Mon 09/18/2017 22:06:06 : [ZWAVE-TX        ] [01030002FE]
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] [0125010205001DBD]...
Mon 09/18/2017 22:06:06 : [ZWAVE-TX        ] [01030005F9]
Mon 09/18/2017 22:06:06 : [ZWAVE-RX        ] [0104010508F7]
Mon 09/18/2017 22:06:06 : Device 25 excluded from Z-Wave network
REMOVE 2
Mon 09/18/2017 22:06:34 : [ZWAVE-TX-NR     ] [0105004B0166D6]
Mon 09/18/2017 22:06:34 : [UZW-CMD 2       ] Start Exclude
Mon 09/18/2017 22:06:34 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:06:34 : [ZWAVE-RX        ] [0107004B66010000]...
Mon 09/18/2017 22:06:34 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:06:34 : Listening for Z-Wave devices to remove from the network
Mon 09/18/2017 22:06:43 : [ZWAVE-RX        ] [0107004B66020000]...
Mon 09/18/2017 22:06:43 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] [0115004B6603000E]...
Mon 09/18/2017 22:06:44 : [ZWAVE-TX        ] ACK
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] [0115004B6606000E]...
Mon 09/18/2017 22:06:44 : Removing Z-Wave devices stopped
Mon 09/18/2017 22:06:44 : [ZWAVE-TX        ] [01030020DC]
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] ACK
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] [01080120EC772964]...
Mon 09/18/2017 22:06:44 : [ZWAVE-TX        ] [01030002FE]
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] [0125010205001DBD]...
Mon 09/18/2017 22:06:44 : [ZWAVE-TX        ] [01030005F9]
Mon 09/18/2017 22:06:44 : [ZWAVE-RX        ] [0104010508F7]
Hope any of that helps :)
I really would like to get to the bottom of this. Very annoying that I cannot control this blind but the others work flawlessly.
-Stephan
Sometimes excluding a Z-Wave device first enables including the device correctly.
I tried that as well in my last attempt that I shared above, I just didn't get the logs for it :(
What you posted shows adding first, then excluding. My suggestion was the reverse, exclude before include. In particular, after selecting exclude and pressing the device button, usually once or twice rapidly, the exclude panel should close if the exclude was successful.
Sorry for not being clear @stusviews. I did remove it first before adding when I did my testrun because I know it sometimes works in that case, but I did not capture the logs. Because of that I did not write it down in my earlier post.
I got this resolved. FYI for anyone who is interested:
I opened a support ticket with UDI and Michael figured out that I hit the node limits of the basic version. Unfortunately the logs didn't say anything about that :(
I upgraded now to the pro version and I can successfully add that device now
