Aeotec Multisensor 6 Motion extremely slow to respond...
Howdy all!  I have an Aeotec Multisensor 6 (on battery power), and I'm trying to use it to turn on my laundry room lights...  I figured this would be simple, but it's proving infuriating.
I have an Aeotec Siren as a repeater as well, but I'm not sure if it's being used in the communication chain.
I have created a simple program:
Laundry Room Motion - [ID 0024][Parent 0017]
        Status  'Inside House / Basement / Laundry Room / Motion Sensor / Laundry Room Motion Sensor' is On
        Set 'Inside House / Basement / Laundry Room / Laundry Room' On
Now - It works, BUT, there is a 35 second lag time from the time that the green light comes on from the Aeotec until the lights actually turn on.
I tested this with my laptop, and from what I can tell, the program executes almost instantly on the ISY, so why does it take so long to trigger the Then??  Any help would be awesome.
It sounds like a communication problem. Put you ISY event viewer in level 3 mode then trigger the motion sensor.
Do you see any error messages in the viewer?
So... I tried removing the device and re-adding it... Same problem.
Then I held the action button down for 3 seconds to put the device in "awake" mode...  Had the ISY issue a Z-Wave HEAL and as soon as it finished everything worked perfectly.
