Need help with viewing a camera outside my home network with ML
I have several Hikvision cameras that record to an NVR.  For a long time, these have worked very nicely by viewing them with Mobilinc.  I recently added a Dahua camera and I cannot connect to it via Moblinc.  In the camera settings for the Hikvisions (which operate correctly), I have the local http:// filled in plus the port number.  I also have an 'Away http://' and port.  For example, it's something like:   http://33.44.55.xyz. I also have a port number which is correctly open in my router.
When I do the exact same thing for the dahua camera, it's not viewable outside the home network.  Any suggestions?
You'll get more answers if you ask in the Mobilinc section.
Sent from my Nexus 6P using Tapatalk
Edited by Gary Funk
Good call.  My mistake.
