Insteon motion 2842-222 program into ISY
I have the UDI ISY also my system is set up and working.  I cannot find the procedure on how to integrate a motion (inseton 2842-222)  to control a light, its programmed into the admin software and working.  I cant find the documentation on how to program a motion to operate a light..
Steve Kopcial
There is no special documentation. You simply add it as a controller of a scene that has the device you want to control as a member, the same as with any other device.
Hi Steve
You can:
1- Use the isy to create a scene, where the motion sensor is the controller and the switch is a responder. The settings of the motion sensor will dictate how long the light stays on. No isy program needed.
2- no scene, write an isy program, where the 'If' statement looks for the motion sensor to be turned on:
If Control mymotionsenor is switched on
Set mylight on
Wait x minutes
Set mylight off
3- a mix of 1 and 2. Create a scene and configure the motion sensor to send On only. Have a program check for the ms switched on, then wait x minutes and turn it off
Paul
Thanks guys,
I forgot the scene , setup just fine...
