More trouble swapping switches
I replaced a switch that had gone bad after trying suggestions listed in another topic I posted.  At the same time I decided to replace an 8 button switch right next to it that has repeatedly had an issue. I am now having the same problem with these 2 new switches that I had when replacing a 6 button switch a few days ago.  The ISY recognizes both switches and made the swap through the admin console. The Insteon and Firmware are both the same, V4.6.2. I can turn the switches on and off manually, and if on I can turn off via the admin console. But I cannot turn then on via the admin console and assume the programming I have with them is not going to work.
I have not had an previous communication issues with the old switches that were there.  Any suggestions?  Thanks!
Being able to turn off only is unusual. If you could turn them on only its a sign that the connected load is generating a lot of noise.
Did you check the On levels of the new switches, either the switch itself or a scene if used. That could be the cause.
Paul
Paul
Problem solved!  You think I would have noticed that the on level was 0%.  Never had that one happen before so didn't even think to look at it.  Thanks!
