Aeon Gen 5 Doorbell
Can the ISY be used to configure the settings of the Aeon Doorbell? Specifically, can the ISY command the doorbell to play a specific ringtone?
100 mp3's can be loaded to the doorbell. I would like to use this device as an annunciator. For example, when a door is opened it would respond "Front door opened" or "garage door opening", etc.
Is this possible? Is there a better way to get voice announcements?
I'd be happy if iSY called it a doorbell instead of a siren.
Sent from my SM-G955U1 using Tapatalk
Edited by Gary Funk
I don't think it can, at this time.
Nope. The only options available from the Administrative Console are On and Off (and Query). Everything else must be manually accomplished by pushing buttons on the doorbell itself.
If you have ZW056-A model doorbell.
Using version 5.0.10
You can use programs to set configuration ( parameter # and parameter value )
Parameter #6  select channel to play
Parameter #7 ( Play = value 1 ) ( Stop = value 2 )
Parameter #2 is number of times to repeat sound.
simple example:
If      $sound is 1
then     set 'voice alarm'  Set configuration parameter 6 = 1    ( channel # 1 select )
            wait 2 secs
            set 'voice alarm'  Set configuration parameter 7 = 1    ( Play )
Parameter #2 is set at 5 so the alarm will repeat 5 times then stop
Thanks for the note on Parameter Support in 5.0.10. Anxiously awaiting official release for GEN 5 support.
